You made me chuckle 😆That's what I needed to know. If it runs, then I will make the fixes, such as new head bolts, new oil and coolant, coolant overflow canister, vacuum and pcv lines that broke. Oh, and I somehow lost a throttle body bolt. I'm not sure the effect that will have but will have to get another.
I don't know if I did anything wrong on the rebuild. If I didn't clean the mating surfaces good enough... When I put the head bolts on, I didn't have an adaptor for the size of the torque wrench to the torx. I used the rachet as I realized it wasn't using ft lbs, but it used degrees. I snugged them by hand in a spiral, then did 90 degrees, and then 45 where it stopped, then I realized that a benefit of a torque wrench is the longer handle, then I used an extension handle on the rachet to finish the 90 degrees, then another 90 degrees, then 45 degrees. I got scared on the last bolt when it felt loose, but it wasn't the bolt. I torqued the head broke on the extension to the rachet. They were all snugged down good.You're entire engine is dead.
80 is the bare minimum needed to fire.
On a gas engine.
Isn't that what people were trying to tell you in your other thread?I don't know if I did anything wrong on the rebuild. If I didn't clean the mating surfaces good enough... When I put the head bolts on, I didn't have an adaptor for the size of the torque wrench to the torx. I used the rachet as I realized it wasn't using ft lbs, but it used degrees. I snugged them by hand in a spiral, then did 90 degrees, and then 45 where it stopped, then I realized that a benefit of a torque wrench is the longer handle, then I used an extension handle on the rachet to finish the 90 degrees, then another 90 degrees, then 45 degrees. I got scared on the last bolt when it felt loose, but it wasn't the bolt. I torqued the head broke on the extension to the rachet. They were all snugged down good.
Could I have messed up the compression test. I did it like the video in Eric the car guy on youtube.
Most likely the head is warped or the rings are bad.
But it was educational taking it apart and putting it back together and fun on a nice sunny day.
That the engine was toast??Isn't that what people were trying to tell you in your other thread?
Yeah. jblackburn said it.That the engine was toast??
I hated the thought of buying an old used car, so I wanted to do what I could to get mine running. It's just way too much to make that happen. There was hope that it would just be a head gasket. Worth a shot.
