1 - 2 of 2 Posts
The 50# fuel injectors from Overkill Motorsport are ready to sale.
Link: www.cruzetune.com www . cruzetune . com
Pricing: $199
One of the first things I wanted to do for the 1.4 Turbo community was find a better fuel injector option. I'm convinced these are the best fuel injector option on the market for the 1.4 Turbo.
These are 50# injectors, larger than the 42# green injectors, will better support high boost pressures and E85 tuning.
Very importantly, they have a projected spray tip, just like the factory injectors; in testing, these injectors idled just like factory, maintained factory fuel economy, you don't even notice they're there. This compares to those who've complained of the idle quality of other larger fuel injectors.
And if they look similar to the factory units, that's because they're made by the same manufacturer, and will be factory reliable. A one piece electrical connector is included with each injector to make them plug and play with the factory wiring harness, and they come with new injector clips.
http://www.getoverkilled.ca/cruze50injectors1.jpg
A minor mod to the fuel rail is required, you need to cut off the locating tab on each injector boss.
http://www.getoverkilled.ca/cruze50injectors2.jpg
And because I'm not the only Cruze tuner in town, I'm providing the appropriate calibration tables for these injectors to provide to your tuner, should you be tuned by someone else but wish to buy these injectors.
Link: http://www.getoverkilled.ca/cruze50injectortables.jpg
Discussion Starter · #2 ·
Note that in my testing these injectors, I found that maxing out the stock fuel injectors was going to be fairly easy. Here at sea level, at 17psi and on a completely factory Cruze aside from tuning, the factory fuel injectors were running at 19-20ms pulse widths. Once swapped to the 50# injectors, the pulse widths dropped to 12.4 at a max at the same 17psi, and ended up in the low 13 range at the end of tuning.
You'll often read or hear about injector duty cycle if you research fuel injectors, and how you don't want to go over 80% or 85% or 90% etc, whatever figure the author may choose. A better way to understand this is through the pulse widths, which is the physical time that an injector is activated to spray, measured in milliseconds...
When you max out the fuel injectors, what you're doing is reaching the physical time limitation that the injector has to spray fuel. This time window shrinks as the engine speed increases. To give this an example, at 3000rpm, it takes 40 milliseconds for the crankshaft to complete 2 revolutions, or to complete its entire 4 stroke cycle. At 6000rpm, it take 20 milliseconds. This 20 milliseconds at 6000rpm represents the maximum amount of time that a fuel injector would have to introduce fuel into the incoming air stream for that cycle.
Now if you compare that to the fuel injector pulse widths I mention above, at 19-20ms, the factory injectors were reaching their maximum by a full throttle shift point of 6300rpm. This means that even if the computer needed to command more fuel into the motor, there wouldn't be the ability to injector more fuel. An example of that need would be if I were to have commanded more boost. Once this maximum time limit is reached, the air/fuel ratio will increasingly lean out from that engine rpm and up, getting leaner as rpms increase.
This should help underscore the importance of knowing when to upgrade your fuel injectors. Again these test figures were at sea level air density, at 17psi on a stock Cruze, and on an Overkill tune that aims for a safe and proper 11.0-11.2:1 air/fuel ratio.
Maximum injector pulse widths can be found by taking 120,000 divided by engine rpm. Here's examples of maximum injector pulse widths in ms, compared to engine rpm:
22ipw = 5450rpm
21ipw = 5700rpm
20ipw = 6000rpm
19ipw = 6300rpm
And if you want to calculate what injector duty cycle is, you take engine rpms x injector ipw, then divide that by 1200. For example, (6000rpms x 20ipw) / 1200 = 100% duty cycle.
1 - 2 of 2 Posts
