1 - 20 of 26 Posts
Hello All
I am Ikram Rao new member in this forum I need a help from you guys, recently I purchased used 2013 Cruze LT after 2 weeks of purchased I found Error Code 89 & 35
so I googled both code & found 35 answer same every where but not 89, some one told me you need to change a engine oil & I have changed but still I am receiving error code 89
please suggest me what should I exactly do to off this error code 89
see attached picture for the error code 89
Land vehicle Vehicle Car Mid-size car Chevrolet cruze
Speedometer Odometer Auto part Light Gauge
Thank You
When you scroll through the available information on the screen, what information is provided?......or, tell me what country the car is in/from.
The 89 code is not used in the U.S. but it is the 'Change Oil' code and must be reset when the service takes place......the car does not actually know you changed the oil.
Hi Rob Thank You FYR
I am from Saudi Arabia and its Korean made car & I found
Error Code 35
(Replace battery in radio remote control) on may web site
http://www.cruzeblog.com/cruze-error-code/
Error Code 89
Forum Chevrolet :: Zobacz temat - CODE 89 w Cruze??
(Service Vehicle Soon) here
Error Code 89
problema tracker code 89
(Thermostat Failure) here
Error Code 89CRUZE-FORUM.DE • Thema anzeigen - Hilfe Code 89 !!!
(Oil Pressuer Senser or Oil Pump Failure) here
this can be a solution but i am still confuse
This You tube video explain how to resolve 89 code issue
https://www.youtube.com/watch?v=M2rzFc7qMqQ
Well, that is confusing information.....oil pumps to thermostats.
Evidently, the code system being utilized is far different than what I've seen and, with that in mind, I would recommend a dealer that could accurately diagnose the cause before just replacing parts.
Good luck!
If you have changed the oil and reset the oil life monitor I'd say the code 89 is pointing at the thermostat, which is a known weak point on the US 1.8L Cruze. If you changed the oil and didn't reset the oil life monitor reset it now and see what happens. The only impact of resetting this monitor is you have to remember to get the oil changed.
Hello Robby & Obermd
Please review attached picture, I capture this from dealer showroom
do you guys think an Error Code 89 I am receiving because my car is around 88,250 KM and its near 90,000 KM & I have to replace all this things...!
- Engine Oil & Filter
- Passenger Compartment Air Filter
- Break Fluid
Vehicle Car Text Mid-size car Font
- Break Fluid
No, not related to your concern.
I agree with Robby - not related.
Hi i live in Greece a have the Aveo ltz diesel i have the same problem with code 89 coming on.They have changed the fuel filter in vain.Now it is in service for econd time i will inform you again.Nick
I have a chevrolet cruse we have this problem today but we solve this by the changing accumulator
What is the "accumulator"? To me this is something that measures and records some piece of information. The only item like this I know of in the gas Cruze is the Oil Life Monitor, which needs to be manually reset each time you change the oil.
My name is shinto chandran (+971558310104) i am also getting same msg code 89 in cruze 2013 model. last day my car was shutdown while driving and it was a horrible experience for me and escaped from an accident. Service personal still searching for the reason. i have informed them that i will take the vehicle from service centre only if company give me a written guarantee letter that this will not happen any more while driving. i am still waiting to get my car and company letter. Symptoms : 1. service message with code 89 (Battery sign) 2. temperature meter Gage showing uneven levels, 3. FM or audio will stop suddenly, 4. Electrical display will shutdown while driving 5. engine shutdown while driving. Only God can help us to solve this issue. Chevrolet cruze company still searching for solution. i got 3 engine shutdown incidents with this cruze 2013. first i have paid 1800 AED. after that 3 days before 2000 AED and now again vehicle in service station (Liberty Service station, Mussafah Abu Dhabi, United Arab Emirates). without solving this manufacturing defects i cannot sell this vehicle. i will wait few more days and after that i will start a campaign against this GM and this particular model (Cruze). company still hiding lots of manufacturing defects and we are suffering.
Hello All
View attachment 186818 View attachment 186826
Thank You
Hi Ikram Rao,
The same issue was there with my Cruze LS 2013,
You check your Coolant level in radiator, mine was solved after refilling it.
Hi Ikram Rao,
Welcome Aboard!(y)
Holden Cruze 1.8L 2012. 63k miles odometer (15-03-2020).
What is the complete name of this accumolater?
As i have the same issue with my chev cruze 2013 in saudi arabia
Not everyone here has english as mother language. The Cruze cannot tell you changed the oil! You have to reset the code 89 warning.
Try this first.
OR...unplug ONE battery terminal for 30 minutes. You will lose cd player/radio settings - minor problem.
Accumulator for car usually means battery. Get your 12v car battery checked using a battery checker tool. Accumulator can also mean a part for air-conditioning system.
1 - 20 of 26 Posts
