BCM/Radio controls a lot, especially when car is "off". Sounds like a terrible way to go about things, should just get the door latch fixed properly. Or it'll just turn off 10 mins after as long as keys are out. Still annoying to hear radio though for those 10 mins.You could probably tear your dash apart and pull the radio out. Run the power wire to some sort of key off wire. Like the old days.
Might have to run a wire to the fuse block or something.
The radio will shut down after RAP goes into effect......about ten minutes.Will the radio turn off after 10 minutes? I haven't left it that long. I can hit the off button but the clock stays lit, which I'm worried will drain the battery. But it would be nice to know the thing shuts off eventually.
I think the ignition has to be on for that screen to work.On the screen between the gauges does it notify you when your door is open? If it does I would think that rules out the door ajar switch
I only mentioned the power wire. I didn't say anything about the controller wires.BCM/Radio controls a lot, especially when car is "off". Sounds like a terrible way to go about things, should just get the door latch fixed properly. Or it'll just turn off 10 mins after as long as keys are out. Still annoying to hear radio though for those 10 mins.
