Ha, was thinking about going back to kerosene lamps, were very reliable before electrical systems came out.
Fogs like anything else in these things are BCM controlled, is a relay on the lower board in that underhood fuse/relay box, but the fuse is on the top board. Pin 31 on the front connector that requires a very special female terminal to plug into that empty terminal slot.
Not sure if HID's will cause interference with other BCM electronic controlled devices. Your 2011 should still be programmed for fogs. Think they quit doing this in the 2013 models so your dealer could charge you an extra hundred bucks to reprogram it. More interested in serving dealers than their customers.
Can always add your own switch, sure to depreciate the value of your car. Most mods do this.
