and made of plastic.
and made of plastic.I suggest you are better off upgrading the front sway bar end links, and perhaps the steering rack bushings. The endlinks are spaghetti thin and probably distort under extreme cornering.
Changing the damping characteristics of the shocks (struts are shocks too) doesn't change the steady state balance of the car's cornering attitude. Damping changes change how the car reacts to DYNAMIC input, ie. sharp turn in moves and/or mid corner bumps. Damping has very little effect on a car's balance. Continued......I still firmly believe that upgrading the struts/shocks will provide a better balanced solution over a rear sway bar.
In order to change the car's cornering balance you need to change the TLLTD (Tire Lateral Load Transfer Distribution). Changes that affect the roll stiffness of the suspension affect TLLTD.The problem with an aggressive rear sway bar is that there is a greater risk of being caught out with the car swapping ends unexpectedly. It could happen as easily as you cornering over a crest in the rain at 50 mph and you back off when the corner tightens up expectantly. Next thing you know you're travelling backwards.
Yes, the front sway bar end links in the Cruze are a weak point. Someone posted part numbers for an all metal Moog end link from a Cobalt (IIRC) that fits the Cruze. Having said that, remember that increasing the effectiveness of the front sway bar in a car that already understeers will make it understeer more.I suggest you are better off upgrading the front sway bar end links, and perhaps the steering rack bushings. The endlinks are spaghetti thin and probably distort under extreme cornering.
Remember, even though the Outside Diameter of the bar may change only a little, if the bar is made from heavier gauge (thicker) material, it can end up being SIGNIFICANTLY stiffer.The Whiteline front bar is a small increase in size from 25.4->27mm. It's not a large change at all, although a change in bar alloy/geometry might make it more effective as well.
I have built a completely adjustable suspension for my track car, a 1974 Datsun 260Z, and can tell you it is not something you want for daily street driven car. And the more adjustability you put into it the more you will be chasing your tail trying to get it right. The stock Cruze (mines an ECO manual) handles really well. The chassis is pretty stiff and the rear end (of the ECO) is pretty lively especially for a FWD which they usually tune in absurd amounts of understeer.I think sway bars are a little more important than you give them credit for. If it weren't for the large size of the stock front bar, the car would handle like crap.
I can't speak with authority for the improvement that replacing the shocks/struts or upgrading the springs does to improve the handling, but I can say the rear sway bar fixed my largest complaint about the handling.
I was looking at simply replacing the shocks with Bilsteins when the time comes to replace the OEM ones, but the B8's (for the sport suspension) run around $700 for a set. I could get the entire B14 kit (coilovers) for $770, so why not spend the extra $70 to get some tune-ability in the suspension as well?
I agree. I suspect most drivers are looking for this input improvement, but mistakenly think a rear sway bar will compensate for it.Changing the damping characteristics of the shocks (struts are shocks too) doesn't change the steady state balance of the car's cornering attitude. Damping changes change how the car reacts to DYNAMIC input, ie. sharp turn in moves and/or mid corner bumps. Damping has very little effect on a car's balance. Continued...
Yeah, my examples are based on steady state cornering on smooth surfaces. In the real world damping has a HUGE effect on cornering stability and the car's ability to handle mid corner bumps and corrections. There's a TON of advancement in shock absorber technology all the time, unfortunately we as car enthusiasts get to play with relatively little of it.I disagree somewhat in that damping may have little affect on a car's balance, however IMO it does provide a more stable action/reaction to a steering or suspension input, if that makes sense. ie, it makes a car more predicable.
Not quite what I have in mind, but it looks exciting!I have built a completely adjustable suspension for my track car, a 1974 Datsun 260Z, and can tell you it is not something you want for daily street driven car. And the more adjustability you put into it the more you will be chasing your tail trying to get it right. The stock Cruze (mines an ECO manual) handles really well. The chassis is pretty stiff and the rear end (of the ECO) is pretty lively especially for a FWD which they usually tune in absurd amounts of understeer.
My Z is put on scales and corner weighted and aligned several times a year. The more adjustments you have the more you have to play with it.
Here a lap at High Plains Raceway.https://www.youtube.com/watch?v=wiNGjx-H-9U
If this is what you have in mind lets do it!
Negative camber does not necessarily increase grip. Lowering your cars center of gravity as well as it's roll center (note that those are 2 different things) in combination with an increase in negative camber can make the initial turn in feel better but unless you are cornering hard enough to make it roll enough to maximize tire contact patch then you may actually have less grip. I run between 2-3.5 negative camber and 4-5 degrees caster (which really helps turn in) but if i dial in too much camber it can really impact my braking because it literally has less tire contact to the road. All track tires have a triangular mark on the sidewall near the tread...it's there to help camber setup for the track. If your tires are rolling over enough to leave wear marks on them then you need to increase tire pressure or increase negative camber. Suspension setup is always a give and take. You can increase camber to increase cornering ability and possibly drastically increase braking distances. My Z is setup very well. I only have about 240 horsepower but am always put in the "A" group with cars that have 400-800 HP and the Lotus' that are always amazing. I don't think they ever touch the brakes.Justinus, another thing to consider is whether or not you plan to use lowering springs in the future.
If you do, consider that the Cruze's front suspension gains significant negative camber when lowered, which increases front end grip. I installed Eibachs and was amazed at how much more grip the front end had afterwards. True, the car rolls a little less because of the additional spring rate, but the majority of the grip increase is camber related. The rear already has quite a bit of camber.
My car is an otherwise stock '12 Eco. The car's balance isn't bad even with just the springs installed. On snow it is possible to get the rear end to come around if you do deliberate things with the steering mid corner, but other than that the car feels pretty good. A very slight increase in rear roll stiffness would probably give it all it needs to feel very balanced, though a sway bar might be too much... I'd then be into what you've done with the front sway bar to get the front end working more.
Installing the z-link is intriguing, but from what I can tell it's not a simple bolt on and requires a rear axle swap.
My car is all stock, and has the exact same behavior. Never had a front wheel drive car before that would do this, which if used to your advantage does improve handling. Much better than a typical FWD under-steering only with the ebrake being the saving grace.On snow it is possible to get the rear end to come around if you do deliberate things with the steering mid corner, but other than that the car feels pretty good.
I always hear this but can't believe from a manufacturing/profit stand point this makes allot of sense. I mean looking at the photo below why would they make a whole new axle just to add one bolt location(one each side)? I do remember a few threads on here that showed two different part numbers for axles, so your probably 100% correct. Again it just doesn't make much sense.Installing the z-link is intriguing, but from what I can tell it's not a simple bolt on and requires a rear axle swap.
Absolutely, but if you look down the side of a Cruze with stock suspension you will notice that the rear wheels have a decent amount of camber (-1.4 deg nominal) while the fronts have almost none (-0.45 deg nominal), and since the rear camber is set simply by the wheel bearing mounting pads and the front relies on the assembly tolerance stackup of many welded sheet metal components as well as the subframe location and strut weldments, the front can vary quite a bit from there + or -. I doubt the camber curve of the suspension is agressive enough to compensate for body roll and keep the tires level to the road surface. All else equal I would expect adding a degree of negative camber to the front of a Cruze, even a Cruze with completely stock suspension, would increase front end grip.Negative camber does not necessarily increase grip. Lowering your cars center of gravity as well as it's roll center (note that those are 2 different things) in combination with an increase in negative camber can make the initial turn in feel better but unless you are cornering hard enough to make it roll enough to maximize tire contact patch then you may actually have less grip.
Interesting. Got any pics or a link to share? I'd like to see that.I want to point out that the WTCC Cruze's do not use the Z-link rear suspension. They tested both setups and found that the ECO twist beam was lighter and actually performed better. I believe that they added reinforcements to the beam for the insane cornering loads they have.
