same scenarios it just happens once every other week for about 5-10 sec.What environment are you operating in........temperatures.....hills.....altitude.....
Worse with A/C operating or no change......
Worse after a hot restart.....
That info can help give clues.
Totally random. It used to happen maybe once every three months now its like everyother weekUnder what conditions do you have the power drops? High RPM, low RPM, steady load driving, accelerations, etc.?
eco M/TAutomatic or manual? I'm sure you've told us before but it makes a difference in where to look.
Its a true cold air so same location as factory. Bottom of the bumper, SCARY to think about with heavy rain.I'm kinda running along the lines of 'heat soak'......operating conditions, specifically heat, ambient and underhood can create a situation that has you running on the edge of spark knock regardless of fuel grade.
These things have a very agressive spark retard schedule that pulls tons of timing and does not recover for several seconds.....makes for quite a lag.
Also....I'm suspicious of your intake.....the stock system pulls air from a point of fairly ambient air temperature.....I believe your system pulls more underhood (hot) air and could put you closer to that timing 'edge' I mentioned.
I am gonna try to monitor IATs just incase in the mean time its just hard with the whole does it when it wants to. I am also thinking wastegate sticking...I'm kinda running along the lines of 'heat soak'......operating conditions, specifically heat, ambient and underhood can create a situation that has you running on the edge of spark knock regardless of fuel grade.
Why would you say that?Sounds more like a turbo issue. The po299 issues doesn't always set off the CEL
Not holding boost do you hear a flutter between gears or while spoiling?Why would you say that?
maybe... i dont know. Why may I ask?you not noticing this after refueling are you? Or sometime shortly after
No no flutter but usually my stereo is up along with the windows...I will keep an ear outNot holding boost do you hear a flutter between gears or while spoiling?
I had the same issue before at one time
