An upset overfilled transmisison, haha.What’s the harm in adding another 1/2 quart or so just for s#its and grins?
If I get to the end of my warranty in 6 weeks, and they haven't done anything, I'm planning to do a level check, then when I refill the lost fluid, overfill it by 4 ounces or so to see how it changes the behavior. If it improves but not completely, I may add another 2-4 ounces at a time until I see complete improvement or it gets worse again, and I know where the optimal level seems to be. I'm also considering using an additional friction modifier to see if I can squeeze any improvement out that way. For the next 6 weeks, though, I'm just waiting and hoping it will completely take a dump or show consistent enough symptoms to repair/replace under warranty.What’s the harm in adding another 1/2 quart or so just for s#its and grins?
The stop-neutral feature on the Aisin 55-50SN was problematic for 99% of them. Often a huge jolt or slow engagement as they got up there in mileage.It definitely seemed to be very happy, for months, when I filled it following the "proper" procedure.
So, either it leaked fluid out again, or something is physically just taking a ****. Based on the fact the couple failures seem to be similar to what we're experiencing, I'm thinking this likely has nothing to do with fluid - especially since it's so intermittent. When our fluid was low, you could basically count on it to be useless.
You could be onto something there. If that starts to go out, you're essentially neutral-slamming the transmission because you're giving it throttle, but it hasn't put itself into gear yet. That's good for it.The stop-neutral feature on the Aisin 55-50SN was problematic for 99% of them. Often a huge jolt or slow engagement as they got up there in mileage.
Most that owned that transmission disabled it or had to replace solenoids.
Surprisingly, it doesn't seem to be an issue for the 6T GM transmissions, but there may be something about the Aisin boxes that still don't like it.
Next time it acts up ask your wife to switch it over to manual shift mode and see if it resumes normal operation to prove that theory... As I understand it putting it into manual shift mode disables the stop-neutral feature...You could be onto something there. If that starts to go out, you're essentially neutral-slamming the transmission because you're giving it throttle, but it hasn't put itself into gear yet. That's good for it.
I've been running AmsOil in near everything I've owned for the last almost 20yrs. The more I hear about how picky manufacturers are with their fluids in their new cars has started to make me think twice about AmsOil lately. This thread don't help, makes me suspicious of how the fluid is treating the Aisin trans. I've got to do my first oil change on my Cruze and not even sure which brand of engine oil to go with anymore. Although, when I called the Chevy dealer, to buy the oil they use seems to be cheaper than if I were to go to the local parts store(with my discount). I'm thinking factory fluids is best anymore...I dunno.
Regarding both of the above posts, this has nothing to do with the fluid. The fluid meets the requirements of AW-1. Automatic transmissions aren't picky about what ATF they use unless the manufacturer specifically designs them for a different viscosity (Honda is doing this lately). The clutch material is more or less the same across transmissions, it's just a matter of the line pressure used to engage those shifts. Don't believe the lie that you need to use an OEM transmission fluid in order for a transmission to function without problems; that's absolutely false. These specifications overwhelmingly deal with oxidation stability and and shear stability; the fluid's ability to withstand stress and abuse over time, not with specific friction characteristics.Ive had the same issues. Ever since I went to amsoil, Ive been dealing with this for roughly 30,000km. Had amsoil in it for 70,000km. Cars been deleted for 75,000km or so.
I want to say its a solenoid that sticky or failing. I have a suspicion that the amsoil has swollen an o ring enough to cause this. My reason being is when the car finally smashes into gear, its aggressive. If the solenoid was failing... It wouldn't last this long. At least with my transmission experience.
The unfortunate reality is everyone wants to remove and replace the transmission. Im not totally convinced that is required... Also, sonnax has a decent read up on behavior issues. My 1-2 shift has always been very rough, however while live scanning it, the car locks and unlocks the converter a ton and seems to be doing its job(has never felt different). We just need to confirm what solenoid controls the neutral while sitting portion.
https://www.sonnax.com/tech_resources/332-adjusting-clutch-control-valves-on-aisin-fwd-6-speeds
@Snipesy , is there something in the computer logs that can be seen that points to this happening?
My wife said she had a particularly heavy "slam" yesterday, but given how inconsistently it happens, I'm not sure we'll ever be able to get the dealer to see it, as it will probably decide to act fine while it is there.
Shifting it into manual - and thus, disengaging the neutral-stop feature - seems to entirely solve the issue.
I have the 6T45 transmission in my 2012 diesel and it seems fine so far. I did notice that if I put the shift in manual mode the transmission doesn't go into neutral when the car is stopped, maybe it is worth trying to see if it makes a difference?Surprisingly, it doesn't seem to be an issue for the 6T GM transmissions, but there may be something about the Aisin boxes that still don't like it.
So, basically, our best shot would be to take it to the dealer and kidnap a tech to ride with us as we demonstrate the issue, when the transmission is currently misbehaving.I'm sure it detects it but that's all proprietary Aisin stuff. Not even GM tools can detect it and frankly I don't even know where to begin with it.
It solves the issue entirely, not going into neutral when stopped.I have the 6T45 transmission in my 2012 diesel and it seems fine so far. I did notice that if I put the shift in manual mode the transmission doesn't go into neutral when the car is stopped, maybe it is worth trying to see if it makes a difference?
