Wow. Works great on my dts.I don't know if it would work or not. Just curious, have you owned a vehicle that has had that option before? I've have owned 3 different vehicles with rain sense wipers and hated that option. They never worked that well in any of the GM vehicles I've owned. To me it was more of an aggravation than help. The from the factory set up that came on my vehicles worked when you had the wipers in intermittent mode, and it basically made it impossible for me to use my intermittent wipers. During light rain events when I needed the intermittent function, the wipers would go from wiping the glass intermittently to running in high speed, then back to intermittent, and the moisture on the windshield did not increase to suggest that it needed to speed up any. Thought it was a problem with the first vehicles rain sense wipers, but the others I owned later did the same thing. May not have that issue with what you are purchasing, but I will try to never own another with that option. May work fine for you.
It might work. You'd have to try it to see if the US Cruze has the programming to make it work.Hi there, recently I had found this OEM rain sensor for Chevrolet Cruze. My car is not equipped with such a nice feature. What if I bought this sensor and installed it. Could it works?
Any one has any idea how the wiring diagrams could be? And do I need any reprogramming?
Until you have to replace the windshield, which insurance often won't pay for OEM glass, which apparently makes a difference to those sensor things.Wow. Works great on my dts.
I've had it on a 2000 model Buick, '08 Z71 Avalanche, and latest gen Yukon/Tahoe, still crap to me. All have operated the same way. Junk IMO. But Sparkman must have got one of the few that actually works as it should, which I have found to be non existent from GM. Have only had only one other non-GM vehicle in my life, and it does not have that feature, thankfully.Until you have to replace the windshield, which insurance often won't pay for OEM glass, which apparently makes a difference to those sensor things.
Almost never worked on our Acura. Incredibly annoying. Granted that was 2003, probably improved since then.
Were any of the Cruzes made in Lordstown shipped to places that had the rain sensor option? If not, then I tend to doubt if the code needed to make it work is even in the US BCM.As for it working, not sure if you need to "Unlock it" like adding ACC and other features the average dealer will turn you down for.
Welcome Aboard!I've been highly researching to find a rain sensor for my 2012 LT Cruze because my car is equipped with the rain sensor fuse and gauge cluster light. My brother in-law works in parts at a Chevrolet dealership. I've actually contacted GM on this because we have searched and searched and can not seem to find this rain sensor part number. I heard back from GM with the part number 13231068 and the harness is PT2565. The harness plugs into the sensor but just has blunt wires coming from the other end. Current issue is I don't know how to wire it up. Are there wires tucked into the headliner?
That part number is actually for an Air Temp Sensor.I've been highly researching to find a rain sensor for my 2012 LT Cruze because my car is equipped with the rain sensor fuse and gauge cluster light. My brother in-law works in parts at a Chevrolet dealership. I've actually contacted GM on this because we have searched and searched and can not seem to find this rain sensor part number. I heard back from GM with the part number 13231068 and the harness is PT2565. The harness plugs into the sensor but just has blunt wires coming from the other end. Current issue is I don't know how to wire it up. Are there wires tucked into the headliner?
It says it’s a temp. sensor but it indeed a rain sensor according to GM. And if you go to a GEN 1 car and look in the gauge cluster in the speedometer near the top there is a light for the auto wipers and in your rear view mirror housing there is a clip to hold it in place.That part number is actually for an Air Temp Sensor.
It's been a long time since I poked around in the ACDelco TDS system or even in the more detailed GDS2 programming, but to the best of my memory I never saw an option for a rain sensor for the Gen 1 Cruze.
This does not fit your: | 2014 Chevrolet Cruze |
