1 - 3 of 3 Posts
hey guys got a question? how to check if your clutch is fully release when pedal at the floor , because my tranny is notchy shifting throught lower gears so idk if my clutch is releasing fully .
If, while stationary, holding the clutch pedal down and waiting a few seconds, you can put in in first or reverse without a grind or engagement clunk, the clutch is fully releasing.
The reason you hold the pedal down and wait before moving the lever is to allow the clutch disc and input shaft to stop turning.
If the clutch is not fully released, the disc and shaft continue to turn and this will present itself as a clunk or grind before/during gear selection.
In general, if the clutch is not fully released, you will have difficulty engaging any forward gear while stationary.
1 - 3 of 3 Posts
