1 - 16 of 16 Posts
· Patience Of Job
Well, it seems I have a very weird issue here, it's intermittent & doesn't do it all the time. It all depend's really but haven't found exactly how to duplicate to make it happen every time. But here are my symptoms -
When you come rolling to a stop you can hear a pop/clicking sound & then when you press the gas just right you can hear the same pop/click sound. it's not a metal sound. So me & a buddy checks the engine mounts best to our knowledge we put it in gear & the engine move's a little bit nothing major but you can see play in it & I understand they would be a little play in the mounts - & then putting the car in park & just kinda rock it back & forth in level ground & you can see the engine moving so my question is - Is this normal?
Yes
Also normal.
Any way you could get the sound on video, though? It is possible a mount or something somewhere isn't torqued correctly - as I recall your car had some pretty serious work done.
· Patience Of Job
Yes, the engine mounts has been taken lose quite a few times. The sound would be very hard to grab on video, as it happens under very specific conditions but once I start to find ways to duplicate it I will. But one thing I forgot to mention is when I was on a hill today & pull I think the throttled need more as you know to pull & the sound was nice a clear. So maybe I can get it to do it again just rare I tell ya.
I am about to be done w/ this car, I thought after engine swap my nightmare would be over.
· Moderator
I think have the EXACT same sound, I just wrote it off as normal. I especially notice it in stop-and-go traffic. I've had a few passengers ask about it when it happens, "What's that clicking noise?".
No idea but it's not affecting me at all.
I hear ya. I may or may not have ordered a Hyundai....
I get a noise and my friends 2014 automatic has the same noise, it is a like a"creak" when you are going slow (creeping) and it is related to hitting the brakes. Like you can hear it in a drive-through (because wall reflect sound) or pulling into a garage.
Not sure if this is what you're hearing just throwing it out there.
· Patience Of Job
I am to the point where I am about done w/ this car. I actually went car shopping for the first time, I am slowly letting go of my Cruze, I went on a Hyundai lot. I started to leave before pulling in but I just pulled right in I have always been a Chevy guy & never jumped ship. But I wanted to see what they had & found a really nice Hyundai Veloster w/ Turbo - packing 201HP which is pretty good for this small car.
I actually love it, the warranty is nice, I am thinking of maybe trading but again very hard & I will need to just sleep on this a long time & make sure I am financially ready to make the move. But once I get everything in order this seems to be the one I love, I never ever considered owning anything else but a Cruze, but this is starting to sicken me.
Any thoughts on this car?
· Moderator
Have you looked at the Elantra Sport? It's basically a Cruze SS and a lot more practical. I'm actually going for the Limited with the N/A 2.0. No turbos. Regular 6 speed with no neutral shifting BS, no start stop, nothing.
· Patience Of Job
Discussion Starter · #10 ·
No, I just actually looked at the stock Elantra didn't like it that much. So they took me to the Veloster man that car was sporty. 7speed auto ( I know I know ) manual would be more powerful. Has the 1.6 GDI motor packing pretty good specs, the only thing I didn't quite like is the turbo that was in it. But @sparkman it was a nice car check that out. & I'll be sure to check out the Elantra Sport.
So from previous post you mentioned that you are having something exactly as I am w/ the poping/click sound during at almost stop & then at slow speed going up.
& a update on the popping/clicking I tried to turn the wheels deep & then gun it slightly to see if could hear the pop nothing & I did both sides. But I do know now that the sound is isolated under the front near the passenger side, @sparkman is your coming from that same end? So I am assuming this rules out a CV joint being bad right?
Ditto on the Sport - looks awesome, and that little 1.6T is good (if a bit noisy when pushed). The new little hatchback GT looks good too, and comes with a less weak 2.0 liter.
The rear axle setup on the Sport completely transforms the car. Actually very nice to drive, and lots of standard equipment.
That's a DCT, so should put about the same power to the ground.
Bad outer CV joint would make a pop, clunk, something when turning sharply. Come to think of it, after my transmission was replaced, I had a creak/squeak every time I let out the clutch. They re-torqued some bolts and everything was ok.
· Patience Of Job
There isn't any popping/clicking sound when turning sharp turns just when you come to a rolling stop right before you completely stop a single "click/clunk/pop" sound will happen you can turn the wheels deep push the gas & nothing then when you pull out depending on the speed or whatever it is you get the single click/clunk/pop" sound.
· Patience Of Job
Discussion Starter · #15 ·
Update : It seems that after having my window down during the really warm day the other day. The sound is most definitely coming from the driver side as well @sparkman also I notice sometimes I am getting a double pop/clicking sound - depending on the situation & speed I am.
Would this be a brake problem? Possible loose pad? Maybe a brake caliper? But would bring the question it would do it every time am I right? & not just random. @sparkman have you found your issue or are you still stumped on this?
· Moderator
I just marked it off as normal. If it explodes it explodes. No use going back to the dealer for me.
Of course, I don't care about mine anymore.
1 - 16 of 16 Posts
