Hello all,
After doing some research on here, I couldn't come up with a conclusion as to whether or not it is safe to jack the car between the two jacking points on the pinch weld. I am trying to put all four jack stands in the jack points to lift my 15 LT RS.
I tried going a few inches off the jacking point and the weld seems to bend after jacking it up, leaving me with not enough clearance to put a stand on the jack point (I have a small floor jack). I was thinking of saw-milling a hockey puck and putting that on top of my jack, it should evenly disperse the pressure applied on the pinch weld and give me enough clearance to put the stands in, but I am unsure as to what might happen if I were to do this in the middle of the pinch weld.
Of course, if you know of any other jacking points that have worked for you, please post ahead and with pictures if possible.
Thanks!
Thanks!
