Dose anyone else have this issue? I'm not sure if it's transmission or engine related. It has a jerking feel to it.
No check engine light or anything hmmm
Mine hiccups a little bit under load off a dead cold engine too. <30k miles on it. If I wait slightly longer to set off and put it in gear, it's fine...so I usually just remote start as I'm walking to it and take it easy on the car on the way out of the neighborhood.I too have a 2nd gen 2016.5 LT 1.4 with the 6 speed automatic that's 100% stock and have experienced this since I bought the car used back in February of this year at 40K miles. It's now sitting at 51K miles and still does it no more or less than it did when I purchased it.
I've done quite a few things to attempt to find a remedy including new spark plugs, compression test, transmission fluid drain and fill, premium fuel, injector cleaner and probably something else I can't think of at the moment. None of these things have had any effect whatsoever on the jerking I'll get from time to time.
I have found that it usually occurs the most once its shifted into 3rd between 1500-3000 rpm under 1/3 throttle or more however I have caught it happening here and there in other gears as well so I've pretty well ruled out it being anything with the transmission. I'm honestly starting to believe that it's a software issue within the factory tune. I keep waiting for a check engine light for a misfire or something but have never gotten a light other than for the ambient air temp sensor which was unplugged by a body shop awhile back and threw a code for it.
This is honestly the only "issue" I've had with this car and I'm strongly considering stopping by the dealer one day to see if there's a firmware update available for the PCM that changes anything with the tuning of the car.
