201 - 220 of 1076 Posts
COTM Winner
I've seen a lot of mention of the whiteline bars cracking. what kind of warranty do they give ?
The Nuclear Option
Discussion Starter · #202 ·
Were you able to get the bar for between the struts? I have been trying to for a year and cannot find it in stock anywhere.
The strut bars are made by Ultra Racing I believe. IMO strut bars and upgraded stabilizer bars do the same thing.
COTM Winner
Strut Tower bar is a body stiffiner. To be honest I peronally dont believe they do much for a a street car. Sway bars actually work with the suspension more.
Reactions: Thebigzeus
The Nuclear Option
Discussion Starter · #205 ·
Strut Tower bar is a body stiffiner. To be honest I peronally dont believe they do much for a a street car. Swat bars actually work with the suspension more.
I stand corrected. I had upgraded sway bars on my Cobalt and loved them.
COTM Winner
Sway bar stabilizer bar same thing or I believe ... its spring steel bar that is connected to both sides of typically the shock or control arm point so that as one side is loaded it essentially lifts on the opposing side .
strut tower brace bars basically tie the 2 tower tops together preventing flex.
The Nuclear Option
Discussion Starter · #207 ·
Yup. Same thing. I've just preferred the term stabilizer bar.
COTM Winner
STBs were literally an appearance mod on the Cobalt as they were already a very stiff car - I'm assuming the Cruze probably is similar, though I'm not entirely sure if it is.
Swaybar, Stabilizer Bar, also Anti-Sway Bar. Lotsa names! They make a huge impact on street driving, though a rear bar moreso than a front bar on a FWD car. The 1.25" rear bar on my Cobalt works wonders with the 24mm SS/SC FE5 front bar, but I would never want to go with a larger front bar.
Reactions: Mr_Pat
The Nuclear Option
Discussion Starter · #209 ·
I had Eibach's front bar on my Cobalt.I think it was 25 or 27 mm something like that. I had TTR's 25.4mm bar in the back.
COTM Winner
Yeah, I recall those and the Progressives being larger than FE5 up front, but that's why I stayed away from them - a bit too large, IMO, for the front of a FWD car. Car doesn't need any help understeering, haha.
Ahh okay, the TTR bar was the 1" bar, which was equal to the Powell street bar. I have the 1.25" Hardcore bar, and then they still have a larger 1.5" XXX Bar.
The Nuclear Option
Discussion Starter · #211 ·
Unexpected Update: I have a problem and I need some help to fix it. I ran out of space, character wise, in my signature for all my mods. :LOL:
Not the end of the world, I know, but I'm open to ideas to rework my signature if anyone has one. I'm not the creative type.
COTM Winner
Keep a separate tab open with the list and paste in at the end of yours posts ?? LOL
COTM Winner
Remove the words pending installation and some of the unnecessary descript words on some of the components maybe and start one part of the list with ZZP - and ll the components leaving out the ZZP in front of each one separately
The Nuclear Option
Discussion Starter · #215 ·
Good idea. Thanks.
COTM Winner
I guess it's better than my signature - ever since we switched to the new forum, I cannot edit it, because it's far longer than it can be, so I can't update anything because I'll have to make it way shorter. :ROFLMAO:
Reactions: JLL
PERFORMANCE MODS: Vermont Tuning E85 Flex Fuel Tune | Injen CAI| ZZP Intercooler & Throttle Body Spacer | 460cc Deatschwerks Fuel Injectors | Ported Intake Manifold | Mishimoto Catch Can | MSD Ignition Coil | NGK V Power Spark Plugs | ZZP Downpipe & Catted Mid Pipe | Magnaflow Stainless Catback Exhaust | ZZP Guage Pod Pillar | Aeroforce Interceptor Scan Gauge | Autometer Sport Comp II Boost Gauge.
PENDING INSTALLATION: Diamond 2816 Forged Pistons • Custom Pauter X Beam 4340 Billet • ZZP Big Wheel V3 Turbo w/Ported Compressor Housing & Wastegate Actuator • ZZP Stage 1 Performance Camshaft & Head Studs • ZZP 72Lb Valve Springs & Titanium Spring Retainers Rods • TTR Front Engine Mount & Rear Transmission Mount • Eibach Pro-Kit Lowering Springs • Koni Adjustable Sport Front Struts & Rear Adjustable Sport Shocks • Whiteline 27mm Front & 22 mm Rear Stabilizer Bars • Whiteline Stabilizer Links
The Nuclear Option
Discussion Starter · #219 ·
Thank you @Blasirl
2013 Cruze LT
From Malaysia???
