981 - 984 of 984 Posts
The Nuclear Option
Discussion Starter · #981 ·
Glad to se the bushings fit .. it LOL sorry I guess I should have taken the shoulder down a touch more .. but I wanted it to be a tight fit so it was unlikely to pop loose from that point . it doesn't stick out beyond the lower edge of the control arm does it ?
I'm not quite sure what you mean, as my Cruze does not have rear control arms, it has a beam axel. But here's a picture of what I think you're asking. :LOL:
Water Automotive tire Light Blue Black
COTM Winner
If you run into any issues let me know. I will hopefully finally be getting to tear my car apart this weekend. I still have some spare stock left from the bushing project so if need be I can redo a set
Reactions: JLL
The Nuclear Option
Discussion Starter · #983 ·
I should be putting the car on the ground sometime next week.
The Nuclear Option
Discussion Starter · #984 ·
UPDATE:
I don't think the AEM Dryflow filter I bought is going to hold very well under power. It deformed after just an hour of run time at idle.
White Light Motor vehicle Black Automotive tire
Therefore I ordered a K&N replacement with almost double the filtering medium area.
Food Rectangle Magenta Gas Cylinder
I also pressed out 1 or the larger control are bushings.
Wood Tire Gas Automotive tire Flooring
