Just installed FK coil overs. Rear ride height question.
2798 4
So finally after 5 years of owning my rig, I've committed to customization. Simply put, I've gotten bored with the car. I am a truck guy. But due to my family situation 5 years ago I went with the most economical decision while staying true to my gm roots and bought the cruze. It's a great car but like I said, boredom sets in, then your appreciation starts to slip.
Anyway....
After installation of the kit, I decided for the rear to remove the adjustability and went straight spring and shock. Fronts are adjusted with just about an inch of clearance to inner wheel well.
I'm not 100% satisfied with the rear ride height. I understand that you typically want a slight height difference due to load in the rear with passengers and cargo. But I was wondering, how can I get a little more drop out of the rear without putting sandbags in the rear? Lol
Is there a company that will take the spring that exists on it and try and match similar spring rate with a slight lower drop?
· Administrator
Anyway....
Are you referring to the coil over springs? If so good luck, hard to find spring rate info from any manufacturer.
I also am not sure what you mean by "straight spring and shock". Are you saying you put the coil overs on the front only?
Oh, and you should post some pics in the [h=1]***Official Lowered Cruze Photo Thread***[/h].
I apologize, body is fighting a cold currently and I am slightly worn out with work and kid and all the dad life stuff lol.
The rear I did the full swap with the lowering shock and spring but didn't install the adjustment sleeves for the rear springs to get the max drop possible. I'm just looking to squeeze out a little more to give the perception of being nearly level.
I will get pics soon. I did the install in two parts along with working a day and night split shift at work and going without sleep for 36 hours due to the split shift so I haven't had alot of time to get good pics. I am very excited to finally be getting more involved with this forum now that I am making the attempt to be one of the first cruzes' in my area that actually has some work done to it.
My area is super saturated with focus sts Hondas and mustangs.
Only met one other guy from elite cruzes that lives nearby that has done alot of work to his.
Anyway....
Posted over on the lowered cruze thread!
