k sport coilovers for RS cruze ?
3712 Views 6 Replies 4 Participants Last post by  Ricklzonai
I have a question about the k sport coilovers
I don't know if i would need to buy camber bolts or replace the ugly sway bars plastics end links for a better ones since im going to be lower ?
Anybody here running this kind of setup ?
1 - 7 of 7 Posts
I would put in both. The factory has little to no camber adjustment. If you are lowering the car you might need a double set. Adjustable shock tower tops might be a better setup.
Remember also if you lower the car you will be pinching the axles as they will be too long. Found that out on a racing Rabbit. Kept blowing out the CV joints. Shortened the axles and the problem went away.
Where can these shorter CV axles be found
Sent from my XT1254 using Tapatalk
We machined our own by removing some material from the inboard of the outside cv joint and reassembling. Not going to work for most folks.
The ksports come with the sway bar end links, adjust them to 10", the stock are 13". As far as the axles are concerned, all depends on how much you lower it, I lowered mine 3 inches and haven't noticed any binding. But that could change down the road. But for now, the ride is amazing!!!!
Good to know. Can take care of that if I have to , still have to get an alignment but I have felt some shaking during certain driving conditions/turning maybe it's the axles binding up
1 - 7 of 7 Posts
