have you gotten an alignment?
Always go alignement after suspension instalation.That i haven't, do you think its a toe in/out issue?
To make sure that everything is tight.what am i checking on the top hats and sway bar.
Too bad you 10 hrs away id check your car for you I can't understand why only in first gear thays funky.top hats are tight, alignment is good but still a small wobble in first gear
I'm pretty sure jakkarro is lower than he is and he dosnt have that problem.its none of the above. its the axles. the lower you go and the closer the axle get to being straight the more they shudder. when you go lower you change the degree of axle angle. for every 1/2 degree of angle lost on the spindle side you need to make up for it on the trans side. and at this time that is impossible. the factors builds this into the car so that at normal ride hight you do not feel it. its the same problem trucks have when they are lifted and or lowered big amounts. we call it "Axle bind" what we do to fix it is to remove the axles and pull the cv's apart and grind down where the axle hits the cv cup and that refill with grease and put it all back to getter. or the other fix it to raise the car back up about a 1/2" at a time till it goes away.
unfortunately 1.5" to 2" is about as low as you can go before you start to get some side effects
true dat! lol i have no problems and im by far the lowest cruze around.I take that back only problem i had was the adjustable endlinks were to short and hit the frame,got fairly annoying so i switched back to the longer stock ones and bam smooth and quiet ride.I'm pretty sure jakkarro is lower than he is and he dosnt have that problem.
Collin isn't he also running coil overs I know he's a 1.4l turbo same axles has him.yes but he is a LS MZO trans...different axles
