1 - 20 of 24 Posts
Hei I'm newbie, I just curious about launc control addition.
Is it enable to add launch control function into cruze from aftermarket ECU?
Example: dastek unichip Q or Q +
my cruze is actually 1,8 LT AT transmission
It's called power-braking. With the transmission in D, get the RPM up to about 2500 RPM with one foot hard on the brakes. Then release the brakes while mashing the gas. That's as close as you'll get.
If you're looking for more power, take a look at the Trifecta tune. Aftermarket ECUs are generally not a good idea.
thanks guys, but why aftermarket ECUs not a good idea? I'm newbie. LOl so I got a lot of question in my head.
Vendor
You can't change the max launch RPM on an automatic via computer tuning. You need to get a different torque converter that locks up later. Launch Control is something we are looking at developing but it would only work on the manual trans cars.
Reactions: nybble
Aftermarket piggyback ECU's are a good idea on a fairly simple car, not on a complex beast like the Cruze. This ECU is "smart" enough to figure out the incorrect signal input and compensate for it.
It's better to find a tuner local to you, or just power-brake on those occasions when you want to launch hard.
And don't power-brake for more than 3-5 seconds. It's very bad for the transmission and can quickly overheat the torque converter.
You can't power brake with this car, or most recent GM products, at least not with mine. If your foot is on the gas and brake at the same time RPM's wil only go up a couple hundred rpms with 0 boost.
Discussion Starter · #10 ·
thanks guys. I've modified the exhaust system on my cruze. But I havent increase the engine compression. How about that? Do I need to increase my compression?
I can cut the head if you want to up the compression lol. To each there own is what they say but in this car it really Isn't worth it keep your good gas mileage and get something better to play with.
Discussion Starter · #15 ·
In my place (Indonesia) there's still lack of racing accessories for cruze.
But, there's one popular engine modification specialist. They suggest me to do some porting n polish, and do some work in the head cylinder to increase the horse power.
Still thinking about it, coz if I decide to do that then the fuel consumption is horrible I think.
Discussion Starter · #16 ·
Do you have any Idea what kind of addition for my cruze? beside cutting the head etc. coz it's extreme I think. hahhaa
I've modified the exhaust system and replace the air filter, with K&N replacement.
I always come onto this website looking for good information, but always feel like I already know what I find.
If you want to launch, replacement ECU's or chips will be useless as the PCM will work around them. The only option right now for the Automatic transmissions is a brakestand. You will need to turn off traction control for this to work correctly as the torque converter is limited with the traction control on. You will notice this if you try to brakestand with the traction control on you will only reach 1500 rpm with no boost. With traction control off you are able to launch at 2500 rpm and in the turbocharged models you are able to build slight boost. (Trick: Turn on the AC system while you spool the turbo, then directly after releasing the brake, quickly switch off the AC. This will supply you with maximum boost pressure at lunch by loading the engine and quickly removing the load as you accelerate. This does take practice to perfect and if you are not careful you can overheat your torque conveter. You have been warned there.)
As far as power adders go to the Cruze, since it is already turbocharged you're going to be looking at a cold air intake and a full exhaust. They are both extremely restricted from the factory to quiet the engine and you will notice a significant difference in performance replacing the set.
The heads really do need some work. Porting and polishing them will make a huge difference in the vehicles performance.
If you are seriously interested in improving this engine, decking (cutting down) the block will give you a large compression increase and improve efficiency, although to be honest I believe the cruze runs stock with an effective compression ratio of about 13.5:1 at 13psi of boost at 6000 RPM so you really dont need to fiddle with that if you aren't serious. Although if you did do that work, while you're in the engine, offset the rod journals slightly to improve compression further. A machine shop will be able to do this work for you. Throw a set of thin piston rings in as well.
As far as HP for you money goes, the intake/exhaust set alongside a TRIFECTA TUNE should buy you a decent performance increase.
In the end, the idea is that the more air you can get into the engine means the computer can add more fuel. MORE AIR + MORE FUEL = MORE POWER!
(Well, at least until you max out the Cruze's tiny injectors, run the engine lean at WOT and blow a rod through the block. ;)) Cheers!
Oh and on a last note, please don't listen to any of these people saying to use copper spark plugs. REMEMBER PEOPLE. The car has a waste spark ignition system. THAT MEANS IT WONT JUMP CORRECTLY ACROSS A SINGLE PLATINUM OR COPPER PLUG. Iridium plugs or double platinum gapped to .035 WITH NO TUNE or to .020 with the trifecta tune will work wonderfully. I would also recommend PENNZOIL ULTRA PLATINUM FULL SYNTHETIC. It's what I run in my Cruze and I wouldn't run anything else. The oil is formulated from natural gas protecting the engine 25% better than Mobile One Full Syn.
All of this is mathematics now guys. We don't run Carbs anymore.
Get rid of the K&N Filter and go back to stock unless you are running an aftermarket intake, then use the Injen/Amsoil filter
This is bad advice, as the A/C will drip water onto the road/track
Not correct. There are practically zero gains from Intake & Exhaust on these cars, they are for cosmetics & sound. The only thing in the exhaust that is restrictive are the cats, really. And for the Intake, just bypass the Resonator, and you have the same affect as a full CAI, just less noise. Also for sound, SRI is louder than CAI and gets better MPG.
Turn traction control off an fit lets you power brake up to 3000rpm's!
1 - 20 of 24 Posts
