Oh, I failed to mention i'm still on the stock BPV.you should be using the green...not yellow. Per my talk with Forge...they said that the springs for the cruze DON'T follow the psi rating charts. Simply green is light and yellow is stronger. Between the green spring and vacuum the BOV should be holding boost just fine weather you are tuned at 22psi or not.
