1 - 10 of 10 Posts
Does the PCM have flex fuel tables in it like the first gen turbos did, and can you add the alcohol sensor and install a tune that enables them?
Have any of the commercial tuners done this yet, or would it be strictly a DIY project in EFILive or similar?
I'm not going to run E85, but I can imagine throwing in 2-3 gallons for an octane boost, and I like the idea of being able to test the alcohol content of my gas by looking at Torque or Scangauge. Even if I wanted to run E85 I'd want flex fuel capability and not be limited to E85.
I’m waiting on this, and a turbo replacement.
Sent from my iPhone using Tapatalk Pro
Im curious about this as well. What other vehicles are flex fuel and use the le2? Would it have to be a sensor from a vehicle that uses the same engine? Anyone got a pin out of a 2017 ecm? :) what problems are you running into, Jerry?
Discussion Starter · #10 ·
I asked for a flex or even just a straight E85 tune when I bought from Jerry at the end of 2018 and he said he couldn't do it.
But that might have changed in the last two years.
1 - 10 of 10 Posts
