Came across a boost leak after I pressurized the system with ~15 PSI. The leak is coming from the intercooler inlet pipe/hose, Where the plastic elbow clips onto the intercooler itself. There is a orange seal in there that I suspect may have worn down since this part can rotate on the intercooler. If I push on the pipe while its pressurized I can get it to stop leaking, It feels like it just needs more pressure on it to make the seal.
Has anyone else encountered this issue? I'm loosing boost because of this leak. I can only get about 18-19 PSI when the ECU is commanding 22.
