Leaking oil
3869 Views 12 Replies 6 Participants Last post by  Chevy Customer Care
The last couple weeks I've notice oil is leaking around the seam where the top plastic cover of the engine block meets the metal underneath the oil cap and dipstick. My oil level isn't low enough to add oil but I am getting a bad burning smell in the cabin when the vent is on. Only 70,000 and 4 years old. Any ideas? Thinking seals may be getting bad but this early?!
It's not puddling on the block but enough to concern me.
Sent from my iPhone
1 - 13 of 13 Posts
Definitely a trip to the dealership time. Sounds to me like you have a pressure related oil leak and since it's with the engine block it will be covered under the powertrain warranty. (Hoses aren't covered)
I was concerned it wouldn't be covered...def don't wanna pay their $75 or whatever it is to "check the car out"
Sent from my iPhone
I can post a couple pics to see if that helps everyone's opinion.
Sent from my iPhone
Here are a couple...hope you can see the moisture all around the "seam"
Sent from my iPhone
Unusual leak point.....I wonder if the fill cap is either incorrectly seated or the leak source......there is a terrific amount of oil being thrown under the cap.....enough so that Chevy added a baffle under the fill cap in 2014.
I didn't know about the baffle? Recall type situation? I've taken the cap off and put it back on multiple times thinking it's not seated properly.
I'm running synthetic oil and it smells like gasoline when I smell the oil cap?! Never sniffed the cap until I came into this problem
Sent from my iPhone
The baffle wasn't a recall or bulletin.....but evidently Chevy saw enough problems at that point to bring the modification on line for the 2014 and subsequent build.
The odor you are picking up on is more from blowby gasses in the crankcase....entirely normal.....the gasses are heavy with fuel odor.
As far as the leak.....purchass a aerosol can of brake parts cleaner and wash off the accumulated oil from the cover......get it good and dry.
Drive it for a day and see what develops......oil doesn't go uphill so if you see something developing you may be able to see the source.
I wouldn't be surprised if the oil cap isn't the cause but will watch for your results.
Indeed. I wouldn't rule out a sloppy oil change. I agree with clean and watch.
I'll clean it in the morning and let you all know. Thanks for the help and interest
Sent from my iPhone
Cool...thanks for the help and interest. Going to clean it in the morning and see how it goes.
Sent from my iPhone
Sent from my iPhone
Keep us posted, hopefully it's just a fluke.
1 - 13 of 13 Posts
