$320 to fix ...not covered under powertrain.... kept noticing wet spots under car ...check... nothing on the top engine compartment view... crawled under with a flash light... oil and coolant everywhere.... transmission belly and oil pan soaked ... coolant spotting on frame.... had to go to the dealer two times before they would acknowledged my leaks ....overflow tank kept getting lower and at a fast rate changing color fast and burning smells as well as smoke coming from the front radiator openings.... check those 1.8 cruzen as well as coolant levels ..could of caused a fire from the looks of it esp the oil running directly on the rear of the exhaust manifold dry to a white crips and then turns black in color
