I have those exact lights, you can see pics of them in my album (not the "garage") on my profile.Hey all was poking around ebay and found these and was wondering if anyone has any experience with them or just opinions!
209 shipped seems like a good deal for 4 brakelights! View attachment 173394
Sent from my SM-N910T using Tapatalk
I don't think i can do that on moible or i just don't know how lolI have those exact lights, you can see pics of them in my album (not the "garage") on my profile.
I've been told they're hard to see when sunlight is shining into the lights themselves, which unfortunately happens quite often....so I find myself checking to see if people behind me are able to see that I'm braking during the day, but out of direct sunlight they are very bright.
Tail lights ar federally mandated! If you don't have rear reflectors then those are definitely illegal. I am sick of being behind theses assholes where you can barely see their brake lights! Get over it! Tinted tail lights are a fad that are dangerous and possibly illegal in most areas?
Taillamps, reflectors--violations, penalty.Tail lights ar federally mandated! If you don't have rear reflectors then those are definitely illegal. I am sick of being behind theses assholes where you can barely see their brake lights! Get over it! Tinted tail lights are a fad that are dangerous and possibly illegal in most areas?
The place on amazon offers a return so i might get these and see if they are bright enough and if not then return and find a pair a little less tinted haha and by Missouri law as long as you can see the red light from far away then it dosnt matter. It dosnt say they have to be red or that they cant be tintedDepending on your location, heavily tinted light housings like those could be illegal for reasons such as anthony has mentioned. I'd check with your local laws if you haven't already before going ahead with these.
They do make a red, reflector version of these taillights that are "legal". If you're worried about cops hounding you I would get those, because these black ones reflect nothing at all and you don't see any red unless they're on, and they're not hard to see either.Taillamps, reflectors--violations, penalty.
307.075. 1. Every motor vehicle and every motor-drawn vehicle shall be equipped with at least two rear lamps, not less than fifteen inches or more than seventy-two inches above the ground upon which the vehicle stands, which when lighted will exhibit a red light plainly visible from a distance of five hundred feet to the rear.
Tinted tail lights are not illegal as long as you can plainly see the red light which is why i was trying to get insight.
Here's a pic with them lit, when the brakes are applied the lights (not on the trunk lid) get about twice as bright. So VERY visible at night, and visible enough during the day.The place on amazon offers a return so i might get these and see if they are bright enough and if not then return and find a pair a little less tinted haha and by Missouri law as long as you can see the red light from far away then it dosnt matter. It dosnt say they have to be red or that they cant be tinted
I've asked several people to drive behind me and tell me how the visibility is and they said they were obviously on or off when applying the brakes. The only complaints I've had are strangers that I assume weren't paying attention to the road and noticed that I braked last minute.
Some guy said "you have absolutely NO taillights" even though I have a very bright, untinted third brake light, plus 2 fully functional tinted lights. I even pulled over to check them to be sure, and they all were completely visible.
No, they're not "DOT compliant" but I don't care, they look nice.
And to answer your question, I've driven all over the state of Illinois, including Chicago, and haven't had an issue with police. That being said, they are a reason to be pulled over so use your discretion on whether you get the black or red ones I guess.
Merry Christmas :th_salute:
God dang those look amazing! If someone cant see you braking then the need their eyes check hahaHere's a pic with them lit, when the brakes are applied the lights (not on the trunk lid) get about twice as bright. So VERY visible at night, and visible enough during the day.
Yeah I kept my stock ones just in case, and they're super easy to switch out, no extra wiring needed. The only extra wire that the new lights have, is if you want the trunk lid lights to be full brightness or half brightness, and I chose half to match the outer lights when they're just normally illuminated at night (when not applying the brake) so that when you press the brakes that outer light is brighter than the inners, and more obviously on.I love the look of them against a white car (i have a white 2015) and as long as you can tell youre braking then i guess theyd be good.
As far as the cops go i dont know about how bad they are i know a few coos will pull you over for window tint but thats really only the small towns here. Id rather deal with the state coos then those assholes.
If nothing else ill keep my stock ones and if i fail inspection in a few years then ill just pop thise out and put the old ones back in.
i had a 99 dakota pass inspection with a broken passanger seat ( didnt move) non working seat belts and a hole in my blinker in the headlight so i really dont kniw what would pass as unsafe in this Missouri lmao
Doesn't mention reflectors which are also mandatory when you are broken down without power on the side of the road.Taillamps, reflectors--violations, penalty.
I have a road side kit in my trunk with 2 reflective triangle things and i belive it has 2 magnetic reflective squares.Doesn't mention reflectors which are also mandatory when you are broken down without power on the side of the road.
Youre the best man you just saved me hours of yelling at my phone cause i couldnt find any info about these lights or any aftermarket lights on the internet!Yeah I kept my stock ones just in case, and they're super easy to switch out, no extra wiring needed. The only extra wire that the new lights have, is if you want the trunk lid lights to be full brightness or half brightness, and I chose half to match the outer lights when they're just normally illuminated at night (when not applying the brake) so that when you press the brakes that outer light is brighter than the inners, and more obviously on.
Yes they are, they have to meet federal and state mandates which in some states say reflectors must "reflect" up to 1000 feet with high beams on.I have a road side kit in my trunk with 2 reflective triangle things and i belive it has 2 magnetic reflective squares.
I dont know if the stock tail lights are even reflective are they?
Huh learn something new everyday hahaYes they are, they have to meet federal and state mandates which in some states say reflectors must "reflect" up to 1000 feet with high beams on.
Do what you want man, I just don't want to give cops a reason to mess with me....
You're welcome! I hope you end up liking whatever you choose to do, and I drive constantly way too fast too haha...have yet to be pulled over in the Cruze, even with obvious mods *knock on wood*Youre the best man you just saved me hours of yelling at my phone cause i couldnt find any info about these lights or any aftermarket lights on the internet!
Thats cool that you can set the trunk lights to 2 separate settings i didn't know that!
Thanks man!
I'd think a daylight shot or a comparison with stock would be more informative.Here's a pic with them lit, when the brakes are applied the lights (not on the trunk lid) get about twice as bright. So VERY visible at night, and visible enough during the day.
