Installed the Gen5DIY LED DRL override harness 280010 and loving it. This harness is for those with second-generation Cruze's that are looking to keep the LED DRL on at 100% brightness when enabling turn signals and at night with the main dipped beam headlights. This is a simple plug-n-play harness that goes inline with each headlight connector and is fed power from the underhood fuse block via a 15amp fuse tap. I tapped into fuse location #15 which also powers the oxygen sensor.
Overall I'm impressed with the quality of the harness and most importantly the install is clean and virtually undetectable.
*Note that because I've also hacked my stock headlight switch to not return to the AUTO position, my DRL's don't turn off when AUTO headlamps are set to OFF.
(can't link more than 1 video :signs006: so only the first one shows up as a preview)
DRL bypass harness + Bi-Xenon + LED hazards flash
DRL bypass harness + LED Turn signal Engagement
https://youtu.be/tHD8nmh1NFs
DRL bypass harness + Autostart Engagement
https://youtu.be/wWo2L_65hSY
DRL bypass harness + LED hazards on
https://youtu.be/XxRKZ0BLLIA
Harness route
Where did the harness go???
Engine bay fuse box
Harness route
Engine bay fuse box
