1 - 8 of 8 Posts
Quick question, I searched and could not find any info on this. My wife's 14 Diesel Fog lights have burnt out. So I was thinking about upgrading them to LED's or something better. Has anyone upgraded to something like this If you have upgraded to anything is there anything that is plug in play with the factory fog lights. Thanks
RS
I am going to eventually get the yellow LED bulbs from Diode Dynamics
Vendor
As a good LED conversion option, you may be interested in Lumen LED kits. They are direct replacements and are just plug-and-play. You will not have to modify your fog lights in order to install a kit. Plus, these kits feature can-bus modules, load resistors, etc. built into them. Here are the links to the options I we suggest you:
Had a set of led fog bulbs in my Cruze for about 8 months and one took a dump. Guessing the module got water in it and corroded because it will blow the fuse instantly. Would recommend trying to move the module up and out of the way as there is a fair amount of water that gets up there it seems. Awaiting a replacement as of right now.
1 - 8 of 8 Posts
