1 - 17 of 17 Posts
2017 Hatch. Looked in owners manual and it says backup lamp is a 921. So I ordered a pair of 921 bulbs from Diode Dynamics.
Only problem...ITS NOT A 921!!!!!!!
The bulb says W21W which cross references to a 7440.
Sent from my iPad using Tapatalk
Interesting.......dimension seems the same.....wedge terminal type.......the only difference (conventional bulbs) seems to be wattage output.
Did you try the new (led) bulbs yet?
I tried a set of 7440 LED bulbs in the reverse sockets. I could not get them to come on at all. So I just put in 7440 Silverstar bulbs instead.
As a side note I also ordered 921 led bulbs and found out they don't fit prior.
Two possibilities: Some LED bulbs are polarity sensitive. So, you may have to pull them out and turn them around.
Second, (and I've experienced this), some LEDs have very narrow leads on the base where the standard bulbs have a "u-turn" shaped wire that give them a wider contact surface. If the fingers in the socket doesn't perfectly align with the narrow LED leads, it won't work. I've had to bend the leads a bit to go across the base at a slight angle and then they work just fine.
I will give this a try thanks.
Discussion Starter · #14 ·
I went through the car and cataloged the bulbs. And my bulbs from Diode Dynamics came yesterday. But I will have a little delay in checking them because...
I’m sure there’s a much easier way to remove the bulbs.
Sent from my iPhone using Tapatalk Pro
Reactions: IPhantom
1 - 17 of 17 Posts
