LED tail lghts
4738 8
Did anybody replace the rear oem tail lights with LED aftermarket lights?
1 - 9 of 9 Posts
The owner's manual says the outer lights are 7443 and the decklid is a 194 - and there's no shortage of LED replacements for that. Forum vendor Diode Dynamics has a page for the 7443 and the 194.
In either case, I'd recommend getting the red ones, not white. The reds will be "LED red". If you go with the whites, they'll have the appearance of a white light being filtered to red.
You also might want to call them to see if the HP3 or the HP5 would be a better match for the 7443 you decide upon. You want the 194 to match the "low" output of the 7443.
While DD might be a little more expensive, I can vouch first hand on the customer service and no-hassle return in trying to find the perfect bulb.
There's a good chance you'll have to add a resistor to your setup to prevent hyperflashing.
1 - 9 of 9 Posts
