Led
1362 Views 12 Replies 4 Participants Last post by  jblackburn
I just bought a 2015 ltz rs...what are the best led lights to buy...i need bright lights to see at night cause i will be getting 5 percent tint...and does this year use reflectors and not projectors?
1 - 13 of 13 Posts
It's reflectors so you shouldn't be putting LEDs in the headlights. Why do you need bright lights to see at night with window tint? I sure hope you aren't putting 5% tint on your front windshield.
Either way, if you need bright just go with a regular incandescant/filament bulb like what's in the car now. It'll have better light output than an LED would. Find one with brighter light output than the stock bulb and you're good to go.
No i wouldnt put tint on windshield but would still like to see better at night
I knew a Cuban co worker in Miami who always drove with her Brights on so she could see better at night. I guess this was the custom in her home land
People like this should not possess a drivers license.
Headlights - retrofit or don't put anything but halogens in them. It makes other drivers hate you when the light scatters everywhere and blinds them.
Aiming the headlights properly (lots are off from the factory - most Cruzes you see on the road seem to have very dim headlights), upgrading the wiring harness, and using ExtremeVision halogen bulbs makes a significant difference in the lighting output of a stock Cruze
do i need to upgrade the wiring harness if i put a higher end halogen bulb in?
Not necessarily. I didn't. It just helps get more voltage to the bulbs.
what is a good halogen bulb…i want the more white effect instead of yellowish. Is the sylvania silverstar zxe good?
[QU OTE=Wodie;2695402]what is a good halogen bulb…i want the more white effect instead of yellowish. Is the sylvania silverstar zxe good?[/QUOTE]
The one I mentioned - Phillips extremevision - is at the top of the category for lumen output. That will help you more than tinted bulbs like the Silverstars (which also very poor life in my experience).
The one I mentioned - Phillips extremevision - is at the top of the category for lumen output. That will help you more than tinted bulbs like the Silverstars (which also very poor life in my experience).[/QUOTE]
thanks
How good are the philips white vision?
philips extreme vision or philips crystal vision….which is better and which would you buy
Any tinted bulbs that will put out a blue/white light look will actually put out *less* usable light. But hey, if you just want it to look cool, there you go.
1 - 13 of 13 Posts
