1 - 1 of 1 Posts
hello, I’m writing because I recently went to replace the light bulb for the drivers side headlight. As soon as I plugged the light in it went right on. Even without the key in the ignition. I then went to the fuse box and pulled the fuse to control the drivers side low beam. So with the fuse out I can still use the high beams but can not use the Low beams unless I insert the fuse again. So for some reason juice is going through the wires 24/7 keeping the light on at all times. I’m pretty stumped so any help would be appreciated.
1 - 1 of 1 Posts
