One advantage to having a car as common as the Cruze is that normally anything that goes wrong has already afflicted a hundred other owners and is well documented in the forums. Such is the case with the PCV/valve cover issue that I recently fixed for the second time.
However shortly after this last fix the car took on a nasty ticking, not the type that you can attribute to normal valve train noise or fuel injectors but the kind you can hear clearly from outside the car with the hood shut and actually triggers a 0324 (knock sensor) code.
The noise seems to have gone into remission a couple times but then comes back as loud as ever.
My initial thought was a sticky valve, however I took the valve cover off again yesterday and found that with two of the rockers (next to each other on the same cylinder on the intake side) I could push them up and down on the lifter side with hardly any resistance. All other uncompressed lifters had firm resistance. I then measured the height of the suspect rockers relative to other rockers that were also in uncompressed position and found them to be at the same height.
My conclusion is that these lifters have failed and no longer retain oil. Its weird though that two lifters side by side would fail unless somehow the one failing affected its peer, and that I've never seen an issue like this for the Cruze in the searches I've done.
The car is a 2012 eco with 124k miles. I've religiously changed oil and filters and always used Dexos synthetic oil.
For the mechanics out there, would you agree with my conclusion that the lifters have failed? If so how daunting would be task of removing the intake cam? I'm guessing at a dealer I would be looking at upwards of $1000.
