I hope so. This thread is in the Gen2 section.Is this the light assembly for a GEN 2 2016 model?
You use 9005. That's the bulb type you need. A 9012 won't fit. 9005 has a 20mm base and 9012 has a 22mm base. It won't fit in the hole, the tabs don't line up, and the connectors are different.HI,
I've tried to figure out what the bulb size and all the website says it's 9012?! I'm confused now. Curently i use 9005, but XtremeVision vustomer support told me that for high and low beams i do need 9012, that's also what amazons suggestions says about bulb types for chevy cruze 2017 premier with projector style housing.
Can someone help me understand what' happening. What is the difference between these 2 types? what should i use?!
Thanks.
