Hey guys, so I have a 2012 Chevy Cruze Eco 1.4 L Turbo Engine. In the past year, I have had so many problems with my Cruze, granted it has 224,000 miles on it, so I expect some problems. This is what I have replaced (here we go, it's long): Turbo charger, thermostat, water pump, serpentine belt, intake manifold, exhaust manifold, clutch, purge valve, MAP, MAF, turbo boost sensor, valve cover, oil pan, oil cooler, bilateral solenoid, multiple hoses, speed sensors, crankcase seal, turbo oil feed line, battery, negative battery cable, possibly more, I can't remember all of them.
So this is my dilemma, when my car was running prior to going into limp mode, the radiator fan wouldn't stop blowing, but other than that, it ran smooth. Although, it is now not wanting to stay on, and the idle seems to loop. No black or blue smoke, no visible leaks, no clunks or squealing, I am trying to make this car last until I get my paramedic certification. I am under no illusions that it will last forever, but it has been a great car up until about 200,000 miles. The codes I'm seeing are as follows:
P0106-Manifold Absolute Pressure/Barometric Pressure Sensor Circuit Range/Performance
P0236-Turbocharger/Supercharger Boost Sensor 'A' Circuit Range/Performance
P0237-Turbocharger/Supercharger Boost Sensor 'A' Circuit Low
P112D- Intake Air Temperature (AIT) sensor 3 circuit high voltage
I cannot afford to take it to a dealership to get it fixed, so I am trying my best to use resources such as yourselves to fix it. Any suggestions would be greatly appreciated. Thanks!
