Want me to come down to Indiana and do it for you?
Including removing the turbo???I love replacing these, I have them down to an hour
warranty pays 2.8, so I better be doing them in an hour. the turbo doesnt need to come out of the car, it just sits in the engine bay. Remove oil feed, remove 10 manifold nuts, disconnect oil drain. the turbo just rests there and oil cooler has enough room to come out. reverse procedure.Including removing the turbo???
I also have a hoist so it makes things alot easier. If your doing this on the ground in a backyard or something its going to take a bit longer.@Know thanks for the info on the process to save some time. You must be a certified mechanic if you have done thousands at this point. The rest of us on this forum will at most probably do it once in the life of our car or not even at all.
Watch out and dont pull back the drain tube too far or it will crack. I've successfully gotten away without breaking I'd say 90% of them, so be careful.@Know thanks for the info on the process to save some time. You must be a certified mechanic if you have done thousands at this point. The rest of us on this forum will at most probably do it once in the life of our car or not even at all.
Will this help?Getting geared up to tackle the oil cooler / filter housing replacement on our 2011 1.4 L Cruze.
I have watched the TRQ video but looking for a write up on this as well.
Would you consider writing a tutorial for us?I love replacing these, I have them down to an hour
Can you just unbolt the drain flange from the bottom of the turbo rather than monkeying around with the block end of the tube?Watch out and dont pull back the drain tube too far or it will crack
yes, just unbolt from the turbo, just be carefull moving the pipe around, they become very brittle and easy to crack/break.Can you just unbolt the drain flange from the bottom of the turbo rather than monkeying around with the block end of the tube?
I have never seen it come any other way, the oil cooler IS the oil filter housing.When I do this I will probably do the cooler and filter housing all as a unit. Parts I will likely source at Advance Auto and I will try to put a list together of must change and good idea to change. Car is a 2011 with about 120,000 miles on it and we do live in the crust belt. Project will likely be done in the June timeframe once I have better weather. I have a 2.5 car garage so covered space is not an issue.
I may. untill then if you have a question just ask.
the thing is, youre removing the whole housing to change that piece anyway. I guess if you wanna save a few dimesApparently some places will sell the whole assembled assembly while some sites show where you can purchase just the cooler portion. There is very little savings with just the cooler though.
