Hello.. I just ran a compression test and it looks like cylinder 4 may have a cracked piston. Do any of you know a reputable hotrod shop in the metroplex that will touch the 2015 1.4 liter turbo?
BNR 60lbs Injectors
73# Valve Springs
E85 Conversion
ZZP Cam
Down Pipe
Titanium Spring Retainers
MRP MAF Holder
Custom Intake w/ 3" K&N Filter
BNR Wastegate Actuator
Bypass Valve Bypass
Racer X Fabrication Intake Manifold
Racer X Fabrication Fuel Rail
MSD Coil Pack
AEM High Flow Fuel Pump
Turbobay Turbo
2 Catch Cans
ZZP PCV fix
Ported and Polished Throttle Body
Full Gasket Matched Exhaust Ported and Polished
AEM AFR Gauge
Tuned
I need to have the block balanced and blue printed.
Thanks in advance.
Chad
BNR 60lbs Injectors
73# Valve Springs
E85 Conversion
ZZP Cam
Down Pipe
MRP MAF Holder
Bypass Valve Bypass
MSD Coil Pack
Turbobay Turbo
2 Catch Cans
ZZP PCV fix
AEM AFR Gauge
Tuned
Thanks in advance.
Chad
