1 - 20 of 24 Posts
if you all are looking for a way to add more whp and over all better performance, I would recommend looking at the Zzperformance kit. I’ve been wanting to do stuff to my Cruze for a long time and I have done my research and still am, but the zzperformance kit is so far a great option. By the end of it you’ll have up to 400whp no problem
You can't increase hp without motor work.
400 horses is going to be very tough if not impossible on a 1400cc motor.
My motorcycle has a bigger engine and I'd be lucky to see 100 hp if i wanted to dump $15g into it. For that kinda money I'd rather buy a new bike.
· COTM Winner
Exactly why @JLL just went through all that work upgrading to forged internals. I'd definitely be leery on the stock stuff!
· Administrator
Well, now that you have been thoroughly bashed, I'm here to ...
Welcome you Aboard!(y)
it is possible, we'll just have to wait and see the ZZP turbo that is currently in development. 400WHP can be achieved as ZZP's drag sonic has that power level. there is a video on youtube that goes over the build. if you were to buy all of ZZP parts available plus the turbo they used with a custom manifold it is doable.
this is the mod list of the ZZP drag Sonic
Full list of current mods:
-ZZP 4340 rods
-Diamond Forged Pistons - 73.5mm
-Ported Intake Manifold
-ZZP 1.4t LUV/LUJ head studs
-1.4 Sonic/Cruze 72# valve springs
-ZZP 1.4t LUV/LUJ performance cams - stage 1
-ZZP LUV/LUJ titanium retainers - 1.4
-ZZP tubular control arms
-BC Racing coilovers
-ZZP 1.4t high voltage coil pack
-ZZP 1.4 turbo tune
-E85 flex-fuel conversion
-N2MB Wot Box
-ZZP Sonic billet engine mount
-AEM wideband UEGO x-series AFR sensor controller gauge w/obdii
-NGK v power spark plugs
-Shifter bushings for sonic
-Sonic cable clamp
-Team m factory limited slip
-Lower transmission mount
-Upper transmission mount
-Clutch Masters aluminum flywheel for cruze/sonic
-Clutch Masters clutch kit for cruze/sonic - fx500 (stage 5)
-Tial wastegate
-Sonic larger throttle body kit
-Turbo is a xona rotor 5751s
-Custom tubular turbo manifold
-Cadillac ATS intercooler core
-Polaris Slingshot radiator
What does something liken that run?
The last time I read someone building 600 horses out of a v8. The heads popped off. He had to weld them on to the block.
Granted that was a couple decades ago.
I still can't see 400 horses out of 1400cc.
I see new bolts in the package but I'd think they'd have to bigger which means drilling the holes in the block.
I bet them piston rods are huge.
What about the crankshaft?
· The Nuclear Option
I don't know what their connecting rods look like but here are my custom Pauter rods. Stock on the right.
Kitchen utensil Tool Wood Metal Composite material
Tool Household hardware Metal Wood Nickel
· COTM Winner
I forgot those were on their website. Those have been out of stock for over a year! :LOL:
That's why I had some custom made.
· COTM Winner
It certainly makes sense - hard to install what you can't get.
1 - 20 of 24 Posts
