I have the same issue!! Haven't noticed any coolant dropping out from under the car but shortly have filling the reservoir it's empty again! Would love to find a solution!
Just a thought....keep an eye on your engine oil as well, if level goes up or you notice foam then most likely your head cylinder gasket is the problem.Hi guys,
A few days ago after a 10 minute drive I noticed a trail of water after parking. The liquid was being forced out of the coolant reservoir under pressure. When the engine had cooled I opened the reservoir and it was empty.
I called the NRMA (NSW roadside assistance). The guy that came refilled the reservoir with water & checked that the fan was cutting in after the engine warmed up. He said it could be the fan's temperature sensor on it's way out - though it was working when he checked. If the fan doesn't cut in the coolant (or water) evaporates quickly.
I told my wife to keep an eye on the temperature gauge when she drove to and from work (20 minutes each way). She said it was normal (a little under halfway). I thought I'd check it anyway and the reservoir is empty again.
Does anybody have any other theories on the cause.
Thanks
Hello Brockster,Hi guys,
Thanks
The NRMA guy tested the fan. By running the car with the AC on the fan should be on. Then he turned off the AC & waited for the temperature to rise. The fan's heat sensor eventually triggered the fan & the temperature gauge was normal when it did.I have the same issue!! Haven't noticed any coolant dropping out from under the car but shortly have filling the reservoir it's empty again! Would love to find a solution!
It's evaporating, that's the only way it goes.I hope I'm not hijacking this thread, but I'm having a similar problem......
2011 Cruze LT, 90,000 miles. At every oil change I check all the fluids - coolant, power steering, bug juice... Never had any loss of coolant. Last oil change was about a thousand miles ago, so not that long. It's been summer, even here in Minnesota, so we hadn't been using the heat, but the temperature gauge has always acted normal. A couple days ago it got cool enough to need heat and there wasn't any. I checked for a 598 code and there's no error code.
So, I checked the coolant reservoir, and it was LOW - not empty, but low. Removed the cap, lots of noise and bubbling, and we had heat. Ran over and got antifreeze and filled the reservoir. Drove it, filled it again. Heat is working fine, as it has for the last 6 years...
There's NO coolant anywhere under the car. There's NO sign that the water pump, radiator, thermostat, or anything else is leaking. Checked under the engine and there's nothing down there. There's no SMELL of hot coolant anywhere. SO FAR, the oil level hasn't gone up, and I don't see any foam.
If it's not going out on the ground, and it's not going into the oil, and it's not staying in the reservoir, WHERE IS THE COOLANT GOING?
Put a bottle of coolant dye in the system and then use a flashlight to find the leak.I hope I'm not hijacking this thread, but I'm having a similar problem......
I found out when my dealership put it in to track down a coolant leak. It turned out in my case to be a combination of a bad water pump and a bad seal on the tank cap.Interesting - I've never heard of coolant dye. I'll have to get some and try it. Unfortunately, since I'd never lost any perceptible amount before, I have no idea how many days it took since I last checked it at the oil change - probably at least 6 weeks ago.
Either way, a small leak somewhere is a whole lot better than pulling the dipstick and finding foam all over it.
Water outlet. I'd consider having the car towed. The failure can go from minor to catastrophic without warning. You do NOT want to overheat this engine. The temp gauge (at least in the US) isn't all that helpful. You can't see actual temperature - just the computer's opinion on if the temp is normal or not.
Yes.So, the black housing at the rear of the engine, with a couple hoses going into it, is the WATER OUTLET?
In the US, the powertrain is 10 years/100,000 miles.I'll find out about the warrany, if any, tomorrow at the local dealer. BTW: I just checked online and it SAYS it's 5 YRS, 100,000 miles. We're past that since the car was bought in November, 2010. I'm not sure where they're covered for 10 years, or if that's applicable to the US, but I"ll check tomorrow.
