1 - 10 of 10 Posts
Loud squealing noise when using brakes I had brand new ones put on a few months after I bought the car. The noise continues to persist and I checked the rear brake discs!!
At this point, the work will have to be checked. Could be cheap pads, or they didn't grease the back of the pads and the slide pins?
Not only that but stability track lights pop on radio turns on and off and after a few days of doing this car completely dies. Then the next day it is back to normal I don’t understand
Classic symptoms of a failed negative cable.
2013 Cruze LT
Is it only when you brake?
My mechanic cut the wrap around the cord to see if they needed replacing he found nothing. The car has done this since a bought it in November of 2020
2013 Cruze LT
You can't see the inside of a cable crimp to see if it's defective.
Reactions: jblackburn
1 - 10 of 10 Posts
