Is there any driveability issues or codes set associated with this ticking? Lots of gm motors have a tick with no ill effects.
Most any motor has a tick after a few thousand miles. Specially the pushrod type.Is there any driveability issues or codes set associated with this ticking? Lots of gm motors have a tick with no ill effects.
Welcome Aboard!:welcome:Getting close to 300K on my 2013 ECO and the ticking started - lots of hesitation and loss of power - and a CEL. I pulled the spark plugs and found them to be not very snug but not tapping loose either. Using an engine stethoscope ($3 at HF) I found the noise was coming from the intake side between #3 - #4 and was most likely a hyd lash lifter/adjuster that had collapsed. I looked into replacing them and it seemed to be not beyond my capabilities but if there is a cheap easy way to try first I'm going to do that. I got a bottle of Motor Medic VALVEMEDIC at the auto parts store $5 - followed the directions TO THE LETTER - it took about 5 miles of Interstate driving and all the sudden it was like someone threw a switch! "Feel that V-Tech -- Yo!" (I know it's not V-Tech but I had to say something). This stuff worked for me and if you have loud ticking maybe you should try it too.
This worked for me! Thank you! Do you have to put a bottle in at every oil change?Getting close to 300K on my 2013 ECO and the ticking started - lots of hesitation and loss of power - and a CEL. I pulled the spark plugs and found them to be not very snug but not tapping loose either. Using an engine stethoscope ($3 at HF) I found the noise was coming from the intake side between #3 - #4 and was most likely a hyd lash lifter/adjuster that had collapsed. I looked into replacing them and it seemed to be not beyond my capabilities but if there is a cheap easy way to try first I'm going to do that. I got a bottle of Motor Medic VALVEMEDIC at the auto parts store $5 - followed the directions TO THE LETTER - it took about 5 miles of Interstate driving and all the sudden it was like someone threw a switch! "Feel that V-Tech -- Yo!" (I know it's not V-Tech but I had to say something). This stuff worked for me and if you have loud ticking maybe you should try it too.
I have a similar problem I pulled my valve cover off and and found that the Gide that the timing chain rides on the two bolts were backing them selves out The sound was a tick that increase with rpm So naturally I thought the worst Hope this helpsI have read what I can see to be all of the threads on the internet and these forums. I understand that it may be the fuel injectors, however my engine did not sound like this the first 20,000 miles I put on it. And now after an oil change at the dealer it sounds like this! I dont think so! I am not a mechanic but I know a few things about cars. I have been through a plethora of problems in the past with a variety of cars. I would just like for once for someone to tell me exactly what is making that noise. How hard is it! Sorry for the vent its just highly frustrating!
Only Diesel engines have injectorsI am pretty sure that's the sound of the Fuel Injectors.. My 1.4L sounds the same. Since the day I bought it brand new. Now have 7700 Miles, and still sounds the same. I run Full Synthetic Castrol Edge. Not Dexos approved, but been using it for years and LOVE IT!!
That's false lol. How else would fuel be atomized into the engine?Only Diesel engines have injectors
i also have a 2012 i now have what sounds to me like valve tap i did make a boo boo changed the valve cover but forgot the oil cap so i had oil everywhere cleaned motor up i was told it could be there is to much oil in the motor and the oil is going over the crank not sure but maybe see if the oil has bubblesHey all I just started to notice this loud ticking noise coming from the top middle of my engine bay above engine block. I should have known something might go wrong when i had to go back to the dealer after my oil change becuase my air pressure sensors were showing that one of my tires had 25 PSI and the other 3 were at 34. Yes I checked that they put oil in the car. I always check everything out after I have any one else touch my car besides me. My engine has always been very quiet until now. I am not just being sensitive to the usual workings of the car. Something is causing this noise and I want to know what it is! Please listen to attached audio for more details. I have found a couple of other chevy owners who have posted similar sounds on youtube but there was no comments on their videos! if you have any ideas on wha this is let me know asap! I am bringing the car to the dealer in a couple days and would like to have some of my own ideas as to what the noise is to discuss with them so I dont get the usual bs back.
Thanks! AUDIO HERE!!!
Welcome Aboard!i also have a 2012 i now have what sounds to me like valve tap i did make a boo boo changed the valve cover but forgot the oil cap so i had oil everywhere cleaned motor up i was told it could be there is to much oil in the motor and the oil is going over the crank not sure but maybe see if the oil has bubbles
Subject: | Buzz Vibration Noise Floor Dash Area 1800-2200 Engine RPM | |
Models: | 2013 Chevrolet Cruze | |
Just had this same problem and didn't see a single person give the answer of what the true issue is. Try changing the canister purge valve, can get one online for $20 or from any auto parts store for about $40 and it's literally 3 clips and switch. I did this and car runs quieter, no more obnoxious ticking and doesn't idle as rough. Hopefully someone else that needs to see this finds it, saved me a lot of stress.Hey all I just started to notice this loud ticking noise coming from the top middle of my engine bay above engine block. I should have known something might go wrong when i had to go back to the dealer after my oil change becuase my air pressure sensors were showing that one of my tires had 25 PSI and the other 3 were at 34. Yes I checked that they put oil in the car. I always check everything out after I have any one else touch my car besides me. My engine has always been very quiet until now. I am not just being sensitive to the usual workings of the car. Something is causing this noise and I want to know what it is! Please listen to attached audio for more details. I have found a couple of other chevy owners who have posted similar sounds on youtube but there was no comments on their videos! if you have any ideas on wha this is let me know asap! I am bringing the car to the dealer in a couple days and would like to have some of my own ideas as to what the noise is to discuss with them so I dont get the usual bs back.
