True, and check for leaks in what you installed as well, never know you might have thought something was tighten down and turns out it wasn'tI'm no turbo expert, but I'm thinking more exhaust volume with your new system translates into reduced velocity which translates into reduced turbo rpms and less boost...
That's strange, colder air should have higher psi rather than warmer air..hmmmmmI had a 2011 ECO 6MT - installed a Borla cat back. I had the trifecta tune - would hit boost in the 20+ psi range. Did notice in summer temps boost was higher by 2 or 3 psi then in winter. Has to do with air density. Did outside temps drop significantly after you installed the exhaust?
What? Boost is measured on the compressor side not turbine side. I think its computer related since its a torque regulated vehicle. Also if you are making the same amount of power at a lower boost level than thats better. Heat accounts for 65% of turbo spool.Boost is a measure of restriction. Less restriction equals lower boost and more volume therefore more power. I do not know the turbo map of our cars but you do not want to lower the boost and end up outside the turbo compressor map.
Yes. The 2.5" SS/TC exhaust combined with the mid-length header and 2.5" downpipe on my Cobalt dropped me a couple psi - but the car is quicker/more powerful as a result.Boost is a measure of restriction. Less restriction equals lower boost and more volume therefore more power.
If he is making the same amount of power at lower boost level than that tells you his kpa is in line.I agree that it is better to make the same power at lower boost but if the turbo is out of its map now, then the turbo is not running efficiently.
