2012 Cruze lt2 with about 58k. Not sure why but I'm having more issues with my coolant level. I keep adding but seems as if it's just evaporating or getting into the core and also emitting an odor. It's faint but I can smell it. I know this was an issue in regards to coolant and the Cruze before because I read about it. Seems to be an issue and was wondering if it's really a factory defect, will gm cover it?
· Administrator
Have you read through any of this yet?
Antifreeze Smell Thread
Also this from Dr. Ober <GRIN>
Water pump or coolant tank cap. This is a sign of one of these two leaking under pressure. Get a bottle of coolant dye and dump it in your coolant. Then you'll be able to find the leak with a flashlight.
As ChevyGuy added it could also be a pressure leak at the spider coupler on the coolant tank side of the engine block.
on my MY2014 1.6L T the coolant was leaking from the reservoir hose connection. The entire reservoir was replaced under warranty as it is a common fault.
The image on the left is the new one, you can see the brass inside the connection is the obvious diffrerence.
