Hi everyone,
It's my turn this morning. Clutch pedal get stuck to the floor. Cruze 2017 LT 76400km.
Wish me luck
Wish me luck
God help you. If you still have powertrain warranty coverage, that's your best chance.Hi everyone,
Wish me luck
Gasoline or Diesel engine?I guess so. It's supposed to be 6y 100000km.
I'd tell myself as well. I could have done what normal people do and buy a Honda Civic, but NOPE, I had to absolutely buy a car made in Ohio so I could "buy American."Since you're The Flash, can you go back in time to tell me not to buy this car? Lots of problems since Day 1.
This one: https://static.nhtsa.gov/odi/tsbs/2018/MC-10143774-9999.pdfIt is a gasoline engine. I should be fine then? What BST exactly? I have seen several of them.
That's a BINGO! Do not sign any paperwork where you pay them anything. They owe you this repair, gratis.Also covered are any actuators directly connected to the transmission (slave cylinder, etc.).
Have you ever by chance had your clutch fluid flushed/bled since you owned the car? I have a 2016 gen 2 with no issues as of yet. As I have mentioned in other threads, I have purged/bled my clutch fluid three times this year since it is such an easy task. Suck out old fluid from clutch bleeder valve while refilling the master brake cylinder. Either I am **** lucky or the purging/bleeding of fluid is definitely mitigating it/keeping it at bay so to speak.Hi everyone,
Wish me luck
Thanks for the reply......Hi Jason,
No I never changed my clutch fluid.
Yes the Brakes and Clutch share the same reservoir and use simple DOT 3 Brake fluid. I am a pretty anal guy when it comes to my cars and preventative maintenance and would consider myself a "seasoned" pro shifting manuals. Have been driving stick since I was 16..I am 47 now... I have both a 2002 Camaro SS 6 speed and a 2021 LT1 V8 6 Speed Camaro as well, so I am very familiar with the "feel" so to speak. I can honestly say my Cruze has felt "OK" and has never really felt any different since the day I drove it off the lot. At least yours is covered under warranty.Hopefully GM will acknowledge the problem and issue a recall. I always feeled like I noob when shifting this car. Something is not right with the clutch. Maybe I'll see a difference after the repair. Maybe there is a way to know if the clutch will go bad.
Is it using the same reservoir as the brakes? One of the caliper jammed this summer. It took a lot of force to push it back in when replacing the rotor. I wonder if it may be related.
If he’s getting the repair for free, why bother trying to prevent the problem? ¯\(ツ)/¯Have you ever by chance had your clutch fluid flushed/bled since you owned the car? I have a 2016 gen 2 with no issues as of yet. As I have mentioned in other threads, I have purged/bled my clutch fluid three times this year since it is such an easy task. Suck out old fluid from clutch bleeder valve while refilling the master brake cylinder. Either I am **** lucky or the purging/bleeding of fluid is definitely mitigating it/keeping it at bay so to speak.
GM technical at HQ knows. The earlier TSBs instructed technicians to bag the removed parts with fluid samples and return those for examination.Of all the threads I have read regarding this issue, I still can not determine what this "debris" looks like that is being shed. It must be awfully large pieces to plug up the orfice tube completely. If the fluid was just "dirty" I cant see how that would plug the line causing the fluid blockage. Is it something that is gelling up so to speak over time. I don't think anyone really knows honestly.
Absolutely never! Recalls cost money and if they can save a dime by ignoring the problem they will do that. There are so few manual transmission Cruze sedans and hatches in North America that GM can skirt by with relatively few problems reported. They'll just hope that the majority of cars age out of warranty coverage and then the problem is your problem. "More than 60,000 miles? That's just wear and tear and you must pay to maintain your car!"Hopefully GM will acknowledge the problem and issue a recall.
You have the opportunity for the mechanic to inspect the clutch when they take the car apart for the warranty repair. Ask them if it's possible for them to replace the clutch if it shows wear, and you pay for the parts and maybe some of the labor for that job while they have everything taken apart. If you ask, maybe they will work with you on that.Maybe there is a way to know if the clutch will go bad.
That's a definite maybe. The safety recall in the EU and UK (Opel and Vauxhall vehicles) is a mandated safety recall. The debris in the hydraulic fluid can damage brake parts. The recall in Europe is a replacement of the slave cylinder, hydraulic pipework, and some brake parts that include the ABS control valve. I guess the debris can deteriorate brake parts and cause brakes to not function properly, so that's a huge safety issue.Is it using the same reservoir as the brakes? One of the caliper jammed this summer. It took a lot of force to push it back in when replacing the rotor. I wonder if it may be related.
Because I was trying to determine if he had done any maintenance in the past................If he’s getting the repair for free, why bother trying to prevent the problem? ¯\(ツ)/¯
WOW! You got the Ferrari of clutch jobs! Nice!They also had to replace the clutch and pressure plate because the brake fluid has leak all over it and damaged it.
