Hey, just a quick FYI for anyone needing this information, I figure someone will need this eventually.
I have a 2011 ECO that had no compression in #3 cylinder (I have not torn down this engine yet, so I don't know the exact failure, but I suspect a piston problem. This car is no longer under warranty, so I had to find an engine. After looking all over the internet for an answer as to whether I could swap in a LUV into this car, I just went ahead and tried it. I can report that my 2011 ECO now has a 2014 LUV engine in it, all I did was swap the intake and exhaust manifolds over from the LUJ. There are no issues with cam timing or anything else.
The reason I wanted to try a LUV engine was that I found one with 20K on it for super cheap. It was half the price of any LUJ, and the LUJs all had high mileage. Plus I didn't want to have another piston issue. Car runs like a champ. Zero issues.
Hopefully this information will help someone. There are a ton more LUVs on the road than LUJs, so it may be a better option for those with engine issues.
