Hi I have a 2014 Chevy Cruze that will not shift into reverse or even slide into 5tj or 6th gear
What I mean by that it will not even let me go all the way right to have the option go up to 5th or even down to 6th please help thank you
Start by swapping out the transmission fluid. This probably won't fix the problem but will at least fix other issues with hard shifting. Next, there are cables running from the gear shift to the transmission. These cables need to be aligned properly for the transmission to move properly into the high gears and reverse. Take a look at post #22 at https://www.cruzetalk.com/forum/9-g...eco-manual-transmission-issue-question-3.html for more information.
