Map sensor-
35090 Views 13 Replies 9 Participants Last post by  Desacrasa
Hi
I have a 2012 Chevy Cruze ECO 1.4 engine an 4 days ago the service engine light came on. I had a computer hooked up to it and it read a code that the map sensor was bad. So I had it replaced today(did it myself as it was really simple)and I test drove it and amount 5 miles into the drive the engine light came back on. Had it retested and the map sensor code came back up. Went took the sensor back got another one and installed that one and on that test drive we were able to drive about 30minues this time before the light came on. Any suggestions on what might be going on here? The car was bought used and no warranty so a dealership is out. Also the map sensor code was the only code that came up both times it was tested.
BTW the car was at about 50,300 when the light came on.
1 - 14 of 14 Posts
What is the actual code # being held in memory......if more than one, what order are they in?
The map sensor monitors boost, maybe there is an issue with the turbo causing a low reading.
If I may go further, the MAP or Manifold Absolute Pressure sensor relays negative or positive manifold pressure.
The manifold has positive pressure on boost, negative pressure (vacuum) while idleing or deceleration or steady speed.......Absolute pressure.
The low boost situations we've heard of are called 'Implausable'........meaning the boost the ecm anticipates is below a pre determined threshold......there is a specific code for this........the ecm anticipates a positive pressure of X, as reported by the maf but it is recieving Y.....a turbo code is the result.
A maf fail code means the information is not being provided.....A diaphram, vacuum source, or electrical failure of the unit.
That's why I was hoping the OP would give the codes in order.
Look for a blown-off turbo/intercooler hose.
Edit: Actually I seem to remember someone saying that their pipe to the throttle body had deformed around the sensor as well and was causing a leak there, so something else to look into.
In other words, always do the old school mechanic stuff first before hooking up the code scanner - check for vacuum leaks from cracked hoses, disconnected hoses etc. Check for pressurized air escaping on a turbo car like Ron White said. If you hear a ticking noise or knocking noise under the hood, use a mechanic's stethoscope to track it down. If you don't have one of those, use a short piece of garden hose and put one end on different areas of the engine while holding the other end to your better ear.
I don't know why butI laughed my ass off when I read that, almost spit out my coffee.
I would do both and use the first code logged to guide me for the physical search for issues.
THanks for the heads up guys. Sorry I don't remember the exact code that came up and it was only the map codes sensor. So I'm going to bit the bullet and take to the dealership and see what they find. I will ask them to check all the hoses and such around the sensor
My car did the same thing. A bad PCV valve (valve cover assembly) shot oil threw the system and wiped the sensor out.
Changed the sensor, still ran like crap. Changed the cover and it was fixed.
Hey Rob, did you ever get this fixed? What did the dealer say?
Aren't there a couple MAF sensors on this car? The only one I know of is the MAF that goes to the cold air intake. I cleaned it once using CRC MAF cleaning ages who when I was chasing a P0171 code. Turns out the issue was a small airline crack in the turbo air intake line. Another common point is the valve covers pressure relief valve failing. I've had both those at some point... meanwhile my dads 2009 Kia Sportage has had ZERO problems like this.
No; there's a mass airflow sensor (MAF) like any car on the intake side, and a manifold absolute pressure (MAP)/ turbo boost sensor in the pipe to throttle body.
  • Helpful
Got it thanks for clearing that up.
1 - 14 of 14 Posts
