I have a 2016.5 Chevy Cruze LT with the RS pkg. I have a knocking noise in the front driver side on rougher roads and bumps. Has anyone else had this issue? if so what was it. I have put it on my lift and checked all the bushings, ball joints, tie rod, and wheel bearing. Everything is tight and solid. The car only has around 30k miles not nearly enought to be having suspention issues already. Problem after problem so far, leaky trunk molding the carpet, leaking water to the battery tray recall, noisy door jambs since new, key fod quits responding sometimes,and now a dang suspention noise. I plan on keeping this car for as long as possible so I am trying to start fixing all of these issues. Not to mention its at EZ Dent now getting hail damage fixed. Any guidance on what else to check on the front end?
