Misfire No Codes Or Lights
8401 Views 3 Replies 3 Participants Last post by  Noahbergfeldt
Hello all,
I have a 2013 cruze eco with 14,000 miles on it. It is experiencing a misfire on cylinder 2 quite a bit under load. Cylinder 1 also misfires about 1/4th as much on similar pulls. There are no lights on or codes stored. I first replaced the spark plugs with those of appropriate gaps the stock delco plugs in fact gapped at 0.30. I then moved them around to see if the misfire followed. It didn't. I then replaced the coil pack from a buddy of mines cruze and the same cylinders misfiring. Back to stock coil. I will next try moving fuel injectors around. I am hoping I don't have burnt valves or cracked pistons. It seems so unlikey with 14,000 miles but I know the engines are notorios for pistons.
Any insight would be appreciated
1 - 1 of 1 Posts
Since your car is under the B2B warranty why haven't you taken it in to your local dealership? You'll have to do a road demonstration, preferably with the tech who will be working on the car.
1 - 1 of 1 Posts
