I have a 2012 Eco M6, and drive 140 miles a day, usually 80-82 on the way to work, and 72-75 on the way home. Speed limit is 70 for 3/4 of the trip.
By some quick math, I can save about $50 a month by running 87 instead of 93. I only actually need 93 when it's hot out. I now run 87 in the winter, 89 in spring and fall, and 93 in summer.
A big intercooler, or alcohol injection should do it under boost, but in hot weather with 87, it will stumble real bad accelerating from a stop if you let the clutch out too fast.
So I'm thinking about freeing up the exhaust. Catless downpipes don't seem to be available anymore, and I'm not sure I'd want one anyway, as I don't think I want a tune, since I'm not looking for more power. Would a mid pipe, and/or cat back make much difference and allow me to run cheaper gas?
I've had an UltraGauge for a while, but just got Torque going today, so now I can see KR. It's like 15* and snowing out now, 87 seems fine in this weather.
What plugs and gap do I want? Most info I've found about plugs is about being modded/tuned/higher boost.
