Oh yeah first thing I do is set my own pressure.From personal experience Walmart sets the tire pressures low. They have set pressures for each rim size. I'd take a look there if you haven't already.
Haven't seen that. That's job #1 now.
That was 10k miles ago so I've pumped it up a few times.
I bought the non fuel max.It is Walmart. Did they put the Assurance Fuel Max back on or plain Assurance?
Not all of it. The OEM Fuelmax tires only add about 3-5% to the car's efficiency. Something else is at work here and I suspect it's the MAF sensor as we've seen this sensor cause up to 10% drop in efficiency when dirty.The tires that originally came with the diesel Cruze will yield you the best milage. You will lose milage with just about any other tire due to weight and tread compound. Matter of fact the OEM TPC rated FuelMax tires on our cars are different then the retail version. I can guarantee the tires are the cause of your lost milage.
That is an opinion.The tires that originally came with the diesel Cruze will yield you the best milage. You will lose milage with just about any other tire due to weight and tread compound. Matter of fact the OEM TPC rated FuelMax tires on our cars are different then the retail version. I can guarantee the tires are the cause of your lost milage.
According to CR they have less rolling resistance than the fuel max. (Pirelli Cinturato)That is an opinion.
I'm telling you. the Pirelli Cinturato Strada AS from Discount Tires are wonderful, ride better, are quieter, and are delivering slightly better mileage than the OEM Goodyears did. This is my second set of Pirellis. My first was on my Sonic 1.4T Hatch, and they really woke that car up in the corners. I believe these are the P7s, but numbered for Discount only.
Wow thats seriously crazy.The OEM Fuel Max is a different tire from the average off the shelf Fuel Max, it weighs 17lbs.
Both. 2/32" less tread, slightly narrower, and lighter construction.Wow thats seriously crazy.
Is it built differently or just less tread to start or both?
